Autococker Barrel Problem
#1 mss2iv
mss2iv
  • 36 posts
Posted 01 December 2012 - 10:18 PM
I have a custom autococker pro stock. I always used a WWA freak barrel back on it. But i bought some other barrels online with AUTOCOCKER threads and i tried to put them on but they wouldn't. I tried everything i could think of. I do have a hard time getting the WWA back on because the body is a lil tight and with the oring the barrel back is really tough to turn but it threads on just fine once you get it started, i know this cus without the oring it threads on and off with no trouble.
Please can you help i have never had this problem with barrels with all the other cockers i have owned.
Storm Tooper 57
#2 Myrkul
Myrkul
  • 586 posts
Posted 02 December 2012 - 01:56 AM
It is possible that they sent you the wrong barrels. compare the threads, you should be able to see an obvious difference.
#3 mss2iv
mss2iv
  • 36 posts
Posted 02 December 2012 - 05:38 PM
I didn't even think of that. I will check that. From just looking at them they look the same, Ill try aligning the threads.
Storm Tooper 57
#4 Mr. Scott
Mr. Scott
  • 454 posts
Posted 01 January 2013 - 04:04 PM
Aluminum threads are easy to mar. If someone ever cross threaded it with a stainless barrel then it can definitely cause problems.
Feedback +22/-0
Yes, the dude with the Ninja Turtles blanket.
Proud to have never sold on PBN
