Tips on what parts to use to make mags
8 replies to this topic
#1 get.lit.up!
get.lit.up!
  • 3,777 posts
Posted 09 December 2012 - 11:40 PM
Hey does anyone have tips on parts to use to make PumpMags or EgoMags (or Electro Pneumatic Mags in general)?
PumpMag:
-Would a X-Valve be overkill or will a classic valve with L10 bolt be sufficient?
-Does anyone else offer a GOOD pump kit compatible with CCM handles other than rainman?
-What 86* frame will work on a Mag? Is there a single trigger Y frame available for purchase?
-Should I buy a classic mag, put a ULE body on it, then send it to rainman or Luke to mill it for a pump kit?
EgoMag:
-What frame should I use? I can get my hand on a aurora Etek frame easily at the moment (I so want a star frame though)
-Is a PPS Pebble the recommend LPR? What other quality LPR should I check out?
-Alternatives for the SMC SY113A-SG-PM3 noid?
-Any Alternative to the MPA-3?
-Is a QEV recommended or required?
-What Rail should I get?
-Anything else I'm missing? (ULE mainbody, Xvalve, trigger frame, rail, LPR, solenoid, ram, pops asa, bike grip, vert. asa, CCM macro fittings, CCM feedleck with locklever, freak barrel)
If you want to give a crash course on PumpMags and/or elecropneu mags please do, I would LOVE to hear it!
NOTE: I'm just collecting cheap parts starting February after I get my S6 or J12(unless I find something uber cheap), until I can acquire an assload of cash.
#2 WiscoBaller
WiscoBaller
  • 2,655 posts
Posted 09 December 2012 - 11:52 PM
PumpMag:
Xvalve is not huge in pump as it is more of a Rate of Fire option.
Dont know
Do not believe so, but I would assume someone like acid could make a single finger trigger for it
That would probably be best, but you would also need to send the rail in.
EgoMag:
Star frames are hard to find, but a lot of people part the egomags, and you should be able to find one.
I have heard good things about the Dragunfly LPR's, work better than ticklers, and I think Renie? made an internal LPR foregrip from the Dragunfly design.
I'd leave it as is, and get one that works. have heard something about the trilogy select fire noids.
Again, trilogy select fire noids
Dont think either or, barbs are normally used
Any rail you want, you mod the frame, not the rail.
Cocker tubing, set screws, sear, board, different asa depending on how you plan to run the LPR (seen most of them run off the asa with a 90* fitting)
The Hooligans Paintball Team
Bob Long Ripper FST
#3 get.lit.up!
get.lit.up!
  • 3,777 posts
Posted 10 December 2012 - 12:05 AM
Would love something like this but with my personal touches
#4 kingJurzy
Posted 10 December 2012 - 01:04 AM
#5 get.lit.up!
get.lit.up!
  • 3,777 posts
Posted 10 December 2012 - 01:09 AM
Just heard that a axe mag is also possible. Looking into it
Edit: new take on a minimag lol
Edited by get.lit.up!, 10 December 2012 - 08:58 AM.
#6 WiscoBaller
WiscoBaller
  • 2,655 posts
Posted 10 December 2012 - 10:32 AM
I think that is an 05 ego frame, not an etek frame. Another good option for having a screen.
Bob Long Ripper FST
#7 get.lit.up!
get.lit.up!
  • 3,777 posts
Posted 10 December 2012 - 02:08 PM
If I can pick up a star frame with everything then I would, but I think a ego 5/6 frame would work
#8 WiscoBaller
WiscoBaller
  • 2,655 posts
Posted 19 December 2012 - 01:14 PM
there is a smokin deal on an egomag frame complete on AO right now.
Bob Long Ripper FST
#9 Dev.
Dev.
    Totally a sophomore member
  • 637 posts
Posted 05 January 2013 - 01:07 PM
Most everything has been answered but to your question about the 86 frame, it is possible with the ccm 86 frame, just requires an extensive amount of modifications
0 members, 4 guests, 0 anonymous users
