tank problems
#1 tot810
tot810
  • 187 posts
Posted 16 December 2012 - 01:04 PM
i emptied my 48/3000 ninja hpa tank last night and now when i shake it it makes a tinking noise is this normal, what do you think the problem might be?
#2 woodsballer414
woodsballer414
  • 1,391 posts
Posted 16 December 2012 - 01:06 PM
Thats normal. Its the seal inside the fill nipple I believe. Without pressure it has nothing holding it in place. It's fine
#3 tot810
tot810
  • 187 posts
Posted 16 December 2012 - 01:10 PM
ok thanks i thought that it was a problem but i guess not, that's a relief
#4 kingJurzy
Posted 16 December 2012 - 01:12 PM
There is no air pushing the pin in place as well as the fill nipple pin.
