tank reg problem
12 replies to this topic
#1 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 18 December 2012 - 06:23 PM
So,today I went out to shoot my gun.When I shot it however,the ball barely rolled out of the barrel.So,I unscrewed the tank to see what was wrong.I then realized that the tank was leaking.So,I first freaked out and put it in my room(because I am one of those paranoid people),and then got a little help from another member here.I now know that the tank is leaking from the pin,and I already tried to pull it up with my fingers to no prevail.Keep in mind that the tank still has about 1500 psi and appears to be putting out a very small amount of air.Any ideas as to whats wrong?
#2 ninjapaintball
ninjapaintball
  • 1,892 posts
Posted 18 December 2012 - 06:36 PM
it could be the gauge not reading correctly? fill that tank and try it again to make sure.
NINJA PAINTBALL - PROUDLY MADE IN THE USA
Ninja Paintball Factory Tech
If you have a question please post it in the NINJA/PSI GURU forum
DOT Certified Hydro Tester G777
#3 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 18 December 2012 - 06:45 PM
I can't get the tank filled until this weekend when I plan on going to play,but I know there is air in it,because it is still leaking from the pin.As I said above,I already tried to pull it up,but that only slightly decreased the leak.Anything else it could be?And thanks for responding back so fast!
Edited by paintballguy2255, 18 December 2012 - 06:45 PM.
#4 ninjapaintball
ninjapaintball
  • 1,892 posts
Posted 18 December 2012 - 07:16 PM
If it is a pin leak then the only way to correct it is to drain it, take it apart and make sure the seat is good or replace the seat.
What brand is it?
#5 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 18 December 2012 - 07:35 PM
Ninja standard adjustable regulator.
And I don't know if I can drain it because the reg is only outputting enough to barely make the ball roll out of the barrel.
#6 ninjapaintball
ninjapaintball
  • 1,892 posts
Posted 18 December 2012 - 08:29 PM
Push down on the pin with a metal object until all the air come out
Then open the reg and look at the seat. If it is dirty and clean which may work? Or you can push it out, flip it over and push it back in with a eraser
Watch the video
http://m.youtube.com...e&layout=tablet
Let me know if you have any more questions
#7 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 18 December 2012 - 09:10 PM
I'll try it.Thanks for helping out!
#8 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 18 December 2012 - 10:19 PM
I just bled all the air out,now how do I get the regulator off?I assume I will either have to go down to my proshop or ship it to you.
Or can I service it while on the tank?
#9 ninjapaintball
ninjapaintball
  • 1,892 posts
Posted 18 December 2012 - 10:23 PM
Watch the pin valve video first.
You can do this but you can always check with your pro shop
Remove the bonnet screws
Turn the bonnet off the body
Remove the piston
Clean the white seat in the bonnet, push it out, flip it over, push it back I with a pencil eraser
Clean and lube the piston
Reassemble.
#10 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 18 December 2012 - 11:53 PM
I cleaned it out and was appalled at all the gunk in it.I bought this used about 3 weeks ago,and this was my first time filling it.It took about 3 q-tips to clean it fully.I also re-lubed the piston o-rings,which hopefully cleared everything up.Thanks again for all your help!
#11 ninjapaintball
ninjapaintball
  • 1,892 posts
Posted 19 December 2012 - 08:56 AM
your welcome and if you need anything else just let me know.
#12 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 25 December 2012 - 11:27 PM
Used the tank this weekend,and it worked flawlessly!
#13 ninjapaintball
ninjapaintball
  • 1,892 posts
Posted 26 December 2012 - 09:25 AM
awesome!
