ASA and Tank threads
#1 marceldacs
marceldacs
  • 1,072 posts
Posted 29 December 2012 - 07:47 PM
just wondering how often if at all ASA and Tank threads last before they wear out. My ASA is on/off but sometimes it takes me a couple turns before the threads catch on. Is there ever a possibilty of air leaking outof the ASA through the threads?
  • 22,432 posts
Posted 29 December 2012 - 07:55 PM
I would think you only have to worry if the threads are so bad that your tank wobbles and can't sit properly. Otherwise, the o-ring on the tip of the tank threads is there for a reason.
#3 walk on pro
walk on pro
  • 310 posts
Posted 29 December 2012 - 10:59 PM
depends on the tank usually it wont really matter if your using a on off but if you arent they can get a little worn down but no big deal myth 1 regs are known to be a little fragile
Horizontal Stock Class CCI Phantom
2011 Proto Rail, Draxxus 68/45 with Ninja Pro Reg, Halo Too with Exalt Speedfeed, CP .685 14 inch 2 Piece Barrel.
#4 Matrixrail_Louie
Matrixrail_Louie
  • 270 posts
Posted 31 December 2012 - 11:36 AM
YEa the o ring is the only thing you really have to worry about
2012 Proto Reflex Rail & Empire z2 for sale- http://www.techpb.co...0
