Phantom Problem
#1 GeezusPB
GeezusPB
    Stud Muffin
  • 610 posts
Posted 05 January 2013 - 03:06 PM
My phantom currently will not cock with air. It feels the same with air as it does without. It sometimes cycles every two shots or so. Does anybody know how to fix this? I have a game tomorrow and really need this fixed. Please help, thanks in advance!
#2 Pyrate Jim
Pyrate Jim
  • 479 posts
Posted 05 January 2013 - 05:21 PM
It sounds like no air getting to the valve.
12 gram or constant air?
I ask because I've had a 12g piercing pin get covered with a bit of foil from the top of a 12g, and caused that kind of problem.
http://www.pbmarshals.com/
Certified Master Airsmith
http://www.paintball-pti.com/
#3 GeezusPB
GeezusPB
    Stud Muffin
  • 610 posts
Posted 05 January 2013 - 06:00 PM
Fixed it :) Btw I use a Ninja 50/4500. I just took it apart and put it back together. No idea how it worked haha. But at least it fixed it! Thanks for the reply though!
#4 The-Phantom
The-Phantom
    Rock N' Cock
  • 3,258 posts
Posted 05 January 2013 - 11:08 PM
phantom's are almost like any piece of technology, all you need to do is power down, and restart and that will fix 90% of your problems
break it down, re assemble it and clean it, and you should be good to go, so much of the problems are simple fixes
glad you got it fixed!
Please feel free to private message me if you have a question about something I've posted!
-Brett
