Empire Axe problem
1 reply to this topic
#1 unstoppablepb
  • 6 posts
Posted 05 January 2013 - 05:55 PM
I just got my axe yesterday and when i try to shoot it you just hear the micro switch click even though its on and there is paint in it. If you shoot with no air you can hear the solenoid click and the only way it will shoot is if you put the pressure at 60 psi and they just fall out of the barrel
#2 Soundwave
    I win paintball.
  • 662 posts
Posted 09 January 2013 - 10:54 AM
Ok, do a few things for me and we'll figure out what the issue is.
First thing: Set your regulator to 180 psi and NEVER CHANGE IT EVER... seriously. Ever.
Second: Replace the battery. Even if you bough the gun new, sometimes the batteries run themselves dry in the box. So go buy a brand new energiser or duracell, don't skimp on cheap batteries.
Third: rest the poppit. You do this by adjusting your velocity screw in all the way and then back it out 3 turns.
Let me know how you're going after all this.
