Wgp 2k+ autotrigger. Need Help.
7 replies to this topic
#1 Tippmannkid15
Tippmannkid15
  • 93 posts
Posted 06 January 2013 - 01:21 AM
Ok, So i have a autococker pump.(2k+). I really want autotrigger for it. I know you can buy the ccm kits and sanchez kits. I already have a nice pump handle all i really need is the frame. What do i need todo? Just buy the whole kit? and which one? or is there a easier way for me? I know you can but the GAT products autotrigger, but im really confused on how that works, plus i cant get the pump arm out of my handle.
Edited by Tippmannkid15, 06 January 2013 - 01:27 AM.
#2 Pump Player
Pump Player
    Voted techpb's #1 sloth
  • 929 posts
Posted 06 January 2013 - 03:27 AM
You need special drilled pump arms. Honestly I would just skip auto trigger. It feels awkward to me. If u didn't already know it is basically a gas free response trigger
#3 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 06 January 2013 - 11:50 AM
Basically this.It is good to have if you are completely screwed over in a game,but isn't worth paying for unless it comes on the gun when you buy it.
#4 Tippmannkid15
Tippmannkid15
  • 93 posts
Posted 06 January 2013 - 01:04 PM
I know, but im trying to build a sick pump. Kinda like a project i want somthing really good and sick and i feel like if i leave out the autotrigger then it wont be as good. So if i just had to buy the autotrigger what would be the best way?
Edited by Tippmannkid15, 06 January 2013 - 01:04 PM.
#5 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 06 January 2013 - 01:13 PM
Then buy a kit that already has A/T installed.This
http://www.paintball...mapugunauk.html
seems to be the cheapest I can find.
#6 Tippmannkid15
Tippmannkid15
  • 93 posts
Posted 06 January 2013 - 01:20 PM
Ok thanks man!
#7 Demon
Demon
    Master Tech
  • 2,087 posts
Posted 07 January 2013 - 12:56 PM
at that price ^ you might aswell look into a CCM kit if you want the nicest stuff, they have an ebay store
Mad Cow Paintball referee and tech
UNL Husker Paintball
"Let's play a game of go fuck yourself, you first..."
#8 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 07 January 2013 - 05:59 PM
This is also true.For $50 more,you can get the deluxe kit,which has everything you could want and is smooth like butter.
http://www.paintball...mau2kaupuk.html
