Wgp 2k+ pump. (Loudness and leak)
6 replies to this topic
#1 Tippmannkid15
Tippmannkid15
  • 93 posts
Posted 06 January 2013 - 06:44 PM
Ok so i have a wgp 2k+ pump. with cp reg cp barrel. My brother has one also, same everything! he has same body same reg same barrel. I noticed his is alot quieter than mine. Even when you dry fire it his is like a thump, mines kind of springy sounding. Also i have a leak coming from my gun and i have no idea where its coming from, its not the bolt.
#2 paintballguy2255
paintballguy2255
  • 2,027 posts
Posted 06 January 2013 - 06:49 PM
Do you cock the gun before you air it up?
#3 cocker addict
cocker addict
  • 1,237 posts
Posted 06 January 2013 - 06:59 PM
You guys probably have different spring set-ups. They can moderate the amount of air the valve releases and thus the sound signature. Also your air leak is probably the valve being held open. You have to either go with a lighter hammer spring or a heavier valve spring.
#4 Tippmannkid15
Tippmannkid15
  • 93 posts
Posted 06 January 2013 - 07:23 PM
Yes, im not that dumb, but its small its not big.
#5 gibbeepbroxzor
gibbeepbroxzor
  • 1,347 posts
Posted 06 January 2013 - 07:34 PM
Your regs and IVG's are set differently, as well as possibly having different valves and springs.
#6 XxJellyFilledxX
XxJellyFilledxX
    Lead Farmer.
  • 3,338 posts
Posted 07 January 2013 - 12:13 PM
+1 on the spring theory.
#7 Demon
Demon
    Master Tech
  • 2,087 posts
Posted 07 January 2013 - 12:53 PM
IVG is just a little bit too loose on the main spring, lets it bounce around a little causing the spring sound typically, also make sure your reg is sweet spotted. if you have to turn your reg down to be in a legal speed, also don't hold the pump forward and chrono it like that, it will be quieter that way but you lose some efficiency.
Mad Cow Paintball referee and tech
UNL Husker Paintball
"Let's play a game of go fuck yourself, you first..."
