Help! anodizing axe and mini problems
#1 koepfsm
koepfsm
  • 4 posts
Posted 09 January 2013 - 12:25 PM
So I'm working on disassembly of these two guns and hit two problems. One is on the mini were the bolt goes is the back of the gun , there is what looks like a steel pin that lines the bolt guide up with the body. Any methods on how to get this out? Second goes for both guns , how do you get the steel studs out of the detent covers? Any help or thoughts on this would be great.
#2 PREDATOR 47
PREDATOR 47
  • 2,422 posts
Posted 09 January 2013 - 01:13 PM
I would say just grab them with pliers and carefully pull them out, although I'm not sure if it's necessary.
#3 koepfsm
koepfsm
  • 4 posts
Posted 09 January 2013 - 01:38 PM
would they be pressed in there or threaded in there? And I know if you leave exposed steel in the aluminum when you electrically charge the acid it will just melt the steel out.
#4 riddler
riddler
  • 1,082 posts
Posted 09 January 2013 - 03:51 PM
Correct. Happens with surprise helicoils a lot.
Doesn't usually result in pitting, but compromising your bath is bad.
#5 koepfsm
koepfsm
  • 4 posts
Posted 09 January 2013 - 04:04 PM
Ya I Just recently anodize a axe and missed the steel that was in the detent covers. The steel was completely gone (melted) and it didnt hurt the aluminum or burn it, but what I did notice when I went to dye it is it took the color alot faster than all the other pieces. I just need to find a way around this ... how to get the steel out or covering it up.
