HELP! want to build a pump
#1 Chase313
Chase313
  • 51 posts
Posted 16 January 2013 - 10:21 PM
So like the title says im wanting to build a pump. A sniper to be exact. The only question I have is where can I buy a Lightning Cocker? I hear they make good pumps. I dont want to buy a pre-made so please dont suggest that, I want to build it myself. Other body suggestions are welcomed as long as theyre relatively inexpensive and readily available. Thanks.
#2 Pump Player
Pump Player
    Voted techpb's #1 sloth
  • 929 posts
Posted 18 January 2013 - 12:56 AM
you cant really get lightnings anymore, but you can go to paintball gateway and get body of choice, ccm internals, nice pump kit, nice trigger frame bolt yadayadayada and there you go. Post shopping cart contents here so we can make sure you have everything!
#3 XxJellyFilledxX
XxJellyFilledxX
    Lead Farmer.
  • 3,338 posts
Posted 18 January 2013 - 07:20 AM
PBgateway is the expensive way to do it. But im sure you can find used lightning bodies for cheapish... Its really just taking the time to hunt all these things down in BST threads and thats the hardest part.
#4 Chase313
Chase313
  • 51 posts
Posted 18 January 2013 - 12:27 PM
okay thanks. my other question would be do "mini"bodies use the same lower tube internals?
#5 XxJellyFilledxX
XxJellyFilledxX
    Lead Farmer.
  • 3,338 posts
Posted 18 January 2013 - 12:46 PM
Not 1,000% sure but i believe they are the same internals.
