Ego 08 efficency problem
#1 alexdiaz1994
alexdiaz1994
    Big Bear
  • 422 posts
Posted 20 January 2013 - 09:39 PM
My ego 08 is only getting 3 pods out of a 4000 fill, why is this? It has a cp reg and hush bolt just incase that matters, and what kind of efficency should i excpect from it?
#2 Soundwave
Soundwave
    I win paintball.
  • 662 posts
Posted 21 January 2013 - 09:12 AM
Ok, first thing I'd like you to do is this:
screw your lpr in or out until it's flush,
reset board settings to factory.
Go out and shoot some more, let me know how many shots you're getting :)
#3 alexdiaz1994
alexdiaz1994
    Big Bear
  • 422 posts
Posted 27 January 2013 - 08:54 PM
Done! Reset to factory, turns out dwell was all jacked up, thank you so much for your help! :)
#4 Soundwave
Soundwave
    I win paintball.
  • 662 posts
Posted 29 January 2013 - 09:06 AM
Anytime buddy :) Remember, Citrus Connection is your friend. Unless you're on the other team... :P
#5 crich775
crich775
  • 218 posts
Posted 04 February 2013 - 06:01 PM
The only two settings I can recommend on the Ego 08 are stock, and 1.5-2 turns in on the LPR and dwell of 14-15, and the second is at your own risk.
Rest In Peace Jacob Espindola 1-12-07
OEF Vet 2011-2012, Combat Infantryman Badge Recipient
