Dangerous Power G3 SE
10 replies to this topic
#1 Redsox33bc
Redsox33bc
  • 74 posts
Posted 24 March 2009 - 09:45 AM
I know that the regular g3 doesnt come with psp 3 shot. However the se comes with an upgraded board, does it have 3 shot? Thanks
ur under 18 and pay for ur own gear put this in ur sig
Redsox33bc - Zombie Survival Crew Member #18, Died seeking out poon
Percentage chance of surviving 3 months, 5%
current setup: Dangerous power g3 se, dye rotor, CP 68 4500 psi tank.
#2 Lucas
Lucas
  • 5,342 posts
Posted 24 March 2009 - 10:10 AM
Dangerous Power
Customer Service: (909) 869-7800 service@dangerouspower.com
Dealer: sales@dangerouspower.com
Hours of Operation: Mon- Fri, 9am to 5pm (PST)
(sorry I tried contacting them, but for some reason my phone lines are down :( ) But theres their contact number,
I've tried looking around online, but I didn't see anything of the sort, its best if you just call them
- Lucas
#3 noregrets05
noregrets05
  • 516 posts
Posted 24 March 2009 - 10:27 AM
ok well yes the se gun comes with the upgrades stock board the has psp 3 shot on it and it also has a two piece barrel and upgraded reg with the new piston for 400 bucks. The regualr stock g3 doesnt come with the the piston for the reg or the stock replacemetn board but if you call DP they will give you the piston for free and they will only charge you 35 bucks for the replace ment board so your looking at like 340 for the regualar g3 so 60 bucks cheaper then the se. Unless you like se colors better there sexy glossy
#4 MurphMan
MurphMan
    Badass Mod ☺
  • 5,951 posts
Posted 24 March 2009 - 02:42 PM
G3 SE - Upgraded Board allowing PSP
Edited by MurphMan, 24 March 2009 - 02:43 PM.
#5 paintballer4ever
paintballer4ever
  • 5,180 posts
Posted 24 March 2009 - 02:47 PM
Very nice board all adjusments are made through trigger pulls
RIP TECHPB
#6 Reece Cook
Reece Cook
    Southern Boy
  • 253 posts
Posted 24 March 2009 - 03:35 PM
Are the regular G3's programmed though the trigger?
Edited by Reece Cook, 24 March 2009 - 03:35 PM.
PM me if you live in Gonzales, Louisiana
XboxLive = I REECE COOK I
Lucas = Moderator
#7 pbplayer77
pbplayer77
  • 629 posts
Posted 24 March 2009 - 05:07 PM
No, only the G3 SE is trigger programmed stock out of the box. With the G3, you will have to buy the replacement board that already comes stock in the G3 SE.
Sig by Stinger, he and Laburton do good work, check em' out.
#8 StandingCow
StandingCow
  • 463 posts
Posted 25 March 2009 - 01:31 AM
Yea, if you get the normal G3... just get the stock replacement board. Then you can program w/trigger and have psp 3 shot.
DP G3
A-5 w/flatline
http://www.techpb.co...w...=16685&st=0 <- Donate to Punk Works for high FPS camera!
#9 Lotus
Lotus
    Tech Guy
  • 4,930 posts
Posted 25 March 2009 - 12:17 PM
There are 3 G3 boards offered by Dangerous Power. The stock board (this is what the G3 comes with $0), the stock replacement board (this is what the G3 comes with, $35), and the APE board (nothing comes with this, ~$80). All are drastically different. The stock board uses dip switches through the trigger and doesn't have the modes you need, while the stock replacement board and APE board are adjustable through the trigger and have the tournament modes you need (but the APE board is much more adjustable and has more modes).
From a performance standpoint, there is no real reason to buy the G3 SE. There are only two things on it that increase performance: the barrel and the stock replacement board board. The stock replacement board can be found for $35 off DP's site, and a CP one piece barrel is better than either barrel on the G3 SE or regular G3. If you buy a G3, stock replacement board, and a CP 1-piece barrel, you'll end up with a better marker than a G3 SE for $35 less. Or you could just not get the CP barrel since the stock G3 barrel is fine and end up with a similar performing marker for $65 less. If you're into the whole "special edition" mumbo jumbo, then there's no shame in getting one to feel "special."
Edited by Lotus, 25 March 2009 - 12:20 PM.
#10 pbplayer77
pbplayer77
  • 629 posts
Posted 25 March 2009 - 05:28 PM
It isn't just special edition mumbo jumbo. It is also better quality, they hand-polish it, better milling, etc. It comes with a lifetime warranty, full set of ball bearing allen keys, better barrel sock, etc. So it is kind of worth the extra $35. You get better stuff inthe box and better quality material.
#11 Lotus
Lotus
    Tech Guy
  • 4,930 posts
Posted 25 March 2009 - 05:59 PM
You don't get better quality material. The internals are all the same. The looks are different, but that's it. It isn't milled any differently, it's just got a polished finish. If a polished finish is worth $35 to you, in my opinion, you're caring too much about looks. Also, if you read the fine print, the "limited lifetime warranty" isn't much better than the other one.
