Need help with my invert mini
#1 invert22
invert22
  • 30 posts
Posted 30 January 2013 - 02:29 PM
If anyone has ever owned a mini can you let me know what the settings should be for the best efficiency. right now mine is 180psi 28 dwell and 1 BiP. Thanks :)
#2 Cookybiscuit
Cookybiscuit
    Schadenfreude Fanatic
  • 15,660 posts
Posted 30 January 2013 - 02:37 PM
Settings are fine, but I'd bump the BIP up a bit.
#3 invert22
invert22
  • 30 posts
Posted 30 January 2013 - 02:41 PM
ok, there is also a slight leak coming from where the bolt is. how would i fix that?
#4 Cookybiscuit
Cookybiscuit
  • 15,660 posts
Posted 30 January 2013 - 02:45 PM
Take a look through the bolt assembly, look for any obvious damage to orings. Pull out poppet and wipe down its face. If it continues replace all orings and relube lightly.
#5 invert22
invert22
  • 30 posts
Posted 30 January 2013 - 02:52 PM
ok thanks
