Empire Axe PROBLEM! NEED HELP!
9 replies to this topic
#1 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 13 February 2013 - 12:39 AM
OK so I just bought a Empire Axe used from this guy and when I went to shoot paintballs couple shot was fine but then all of a sudden some balls was rolling out! Anyone help please help explain and find me a solution!
Edited by Hyrinmaru, 13 February 2013 - 12:41 AM.
#2 Steephill
Steephill
    Dota 2 > Life itself
  • 3,477 posts
Posted 13 February 2013 - 01:39 AM
Chillax, it sounds like it's just the detents. Check and make sure they're in good condition, if not pick up a new pair. Also what hopper are you using? If it's putting too much pressure on the ballstack and the detents are barely hanging in there then it'll push balls past.
My Feedback +14/-0
#3 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 13 February 2013 - 01:42 AM
Alright I'll try replacing it
#4 Soundwave
Soundwave
    I win paintball.
  • 661 posts
Posted 13 February 2013 - 02:12 AM
You shouldn't need to replace anything. There are a few things you need to try. First, this belongs in the tech support section of the forums.
Secondly, tell me what you mean by rolling out.
Were the paintballs just barely being shot out?
Were they rolling out on their own when you had the gun pointed down?
Have you been able to repeat the problem?
If you can, take some video for me and I'll get this sorted out for you :)
#5 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 13 February 2013 - 02:43 AM
Like when I shoot the marker paint balls fly out like around 2 to 3 and then I Notice few of them were falling out like rolling out of my barrel while I was shooting it and at the same time it was falling out it wouldn't shoot anymore paint out of the marker. Was using a gravity fed hopper was that the problem and was using a 3000psi tank so is it?
#6 Soundwave
Soundwave
    I win paintball.
  • 661 posts
Posted 13 February 2013 - 06:02 AM
Put a new topic in the "Tech Support" section, and I'll help you sort this out once and for all :)
#7 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 13 February 2013 - 09:24 AM
Can you give me the direction to get to Tech support?
#8 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 13 February 2013 - 12:12 PM
Posted it there
http://www.techpb.co...howtopic=212791
#9 cybermaniac15
cybermaniac15
  • 5,450 posts
Posted 13 February 2013 - 01:42 PM
There is really no reason that he should have to do that, this is the newbie section, obviously he is a newbie. SMH..
#10 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 13 February 2013 - 02:34 PM
True true!
