EMPIRE AXE PROBLEM NEED HELP!
#1 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 13 February 2013 - 12:11 PM
OK so I just bought a Empire Axe used from this guy Like when I went to shoot the marker paint balls fly out like around 2 to 3 and then I Notice few of them were falling out like rolling out of my barrel while I was shooting it and at the same time it was falling out it wouldn't shoot anymore paint out of the marker. Was using a gravity fed hopper was that the problem and was using a 3000psi tank so is it?
#2 Vidalecent
Vidalecent
    Low-end <3
  • 233 posts
Posted 13 February 2013 - 01:29 PM
Sounds like your detents are bad. Replace your detents.
#3 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 13 February 2013 - 02:38 PM
I'll post some pics for you to see and can you tell me if their bad or not? Picture of the white ball something like that right? (pretty new to pb so my bad if I can't explain it well)
#4 Vidalecent
Vidalecent
    Low-end <3
  • 233 posts
Posted 13 February 2013 - 03:29 PM
Okay. Oh, heads up, you don't need to post the same thing in different places here. Just once should be enough. :D
#5 cybermaniac15
cybermaniac15
  • 5,450 posts
Posted 13 February 2013 - 04:26 PM
Its true, but somebody else had to be douchey. Lol
If its still in, that may not be the problem.
Now if it wouldn't shoot anymore, that could be 2 things.. Either there wasn't a ball in the breach, or you're having some sort of bolt/poppet stick issue.
Edited by cybermaniac15, 13 February 2013 - 04:25 PM.
