Need help with a Bob Long Marq7
7 replies to this topic
#1 D.A.M.Baller321
D.A.M.Baller321
  • 598 posts
Posted 16 February 2013 - 12:42 AM
I just recently perchased a Bob Long Mark7 and I just have a some questions. First what lube should I use? Will hater sauce work fine? Second where can I download a owner's manuel? I checked the web site and its not on there. Thank you for the help.
My link LNIB Dye D.A.M.
#2 tallsmallboy44
Posted 16 February 2013 - 12:45 AM
I believe Dow 55 and triflow.
I believe this is the manual
#3 andrewthewookie
  • 22,435 posts
Posted 16 February 2013 - 12:49 AM
Dow 55 is recommended, however, any standard paintball lube should work fine.
#4 D.A.M.Baller321
D.A.M.Baller321
  • 598 posts
Posted 16 February 2013 - 12:50 AM
Where can get dow 55 and airflow?
#5 tallsmallboy44
Posted 16 February 2013 - 12:53 AM
I think macrolineguy.com has some.
Edited by tallsmallboy44, 16 February 2013 - 12:55 AM.
#6 Duke Scrotum
Duke Scrotum
    Fuck Anticipation guy...Right in the Butt!!!
  • 2,518 posts
Posted 16 February 2013 - 02:49 AM
well I can tell you from experience that hater sauce works fine, and some other fine gents have given you a link to the manual.
Gearbag Sale
Because, I have a problem.
And the only way it will be better is if I have more guns.
#7 Latsabb
Latsabb
    Your resident gun whore.
  • 10,625 posts
Posted 16 February 2013 - 03:37 AM
If a grease other than Dow 55 (such as Dow 33, Hater, whatever) will work on any particular Marq is highly dependent on each individual Marq. Some work fine with Dow 33, some dont. The more wear on the o-rings, the higher the chance that you will need to use Dow 55. Both of my Victories, and my Darq Marq, worked perfectly fine with Hater, Gun Sav and Sleek. A Victory at my field, however, HAD to have Dow 55 on the blast guide, or it would start to leak after a couple hundred shots. Dow 55, in general, will also last longer before you need to relube on the Marqs, as it is thicker.
Edited by Latsabb, 16 February 2013 - 03:38 AM.
Oderint Dum Metuant
#8 D.A.M.Baller321
D.A.M.Baller321
  • 598 posts
Posted 16 February 2013 - 08:32 AM
Thank you guys. You have been more than helpful.
