pin valve removal?
#1 pc_baller
pc_baller
  • 221 posts
Posted 22 February 2013 - 04:09 PM
is it possible to remove the pin valve from an empire bonnet cause i just got a new bonnet from ans and its just the threads with no pin in it so is there a way to swap the pin from my old bonnet to my new one?
+2/-0my feedback
#2 ninjapaintball
ninjapaintball
  • 1,892 posts
Posted 22 February 2013 - 04:11 PM
you should be able to remove the old bonnet and use the parts from that in the new one. just make sure it is the same bonnet and not one form a different manufacturer.
NINJA PAINTBALL - PROUDLY MADE IN THE USA
Ninja Paintball Factory Tech
If you have a question please post it in the NINJA/PSI GURU forum
DOT Certified Hydro Tester G777
#3 pc_baller
pc_baller
  • 221 posts
Posted 22 February 2013 - 04:16 PM
okay and yes its the same manufacturer but how would i go about getting the pin out does it twist out or what?
+2/-0my feedback
#4 ninjapaintball
ninjapaintball
  • 1,892 posts
Posted 22 February 2013 - 05:08 PM
check with kee but you have to remove the bonnet and pull out the pin to put it into the new bonnet
