Ion air leaking through barrell
10 replies to this topic
#1 Devers
Devers
  • 2 posts
Posted 25 March 2009 - 08:57 PM
Hey Mike and TechPb community,
I had just come back from a day of play at a local field, shot a case through my ion and came home. When I can home to dry fire the air out of it, it was fine until the tank was empy, air was coming from the inside of the marker through the barrell. I posted this on pbnation and just got chirped and had the old "just throw it out and get a decent gun." Could everyone please help me out.
Thanks, Deverss
#2 Ames
Ames
    I hated ions beafore it was cool
  • 1,046 posts
Posted 25 March 2009 - 09:02 PM
i dont think pb nation really helps anybody.
its probably just jammed forward
check if the bolt is pushed back all the way, if it isnt just push it back. their isnt enough air in it to push the bolt back all the way to close off the air supply
Beautiful Raceframe'd round body CCM S5
Virtue'd Vlocity
68/45 Maxflo
CP 10in .685 barrel
#3 i have a 09 slg
i have a 09 slg
    [rebmem][member]
  • 376 posts
thats what happens
#4 Lucas
Lucas
  • 5,342 posts
Posted 25 March 2009 - 09:03 PM
Your problem:
I can almost guarantee you that your issue is your o-ring.
If your gun is can still shoot but has a leak the air sealant isn't good so you need to check your o-rings and replace whichever ones needs.
Feel free to message me ;)
- Lucas
I'm sorry that on PBN that people treated you the way here. We have some great members that are more than happy to support you ;)
#5 KonekoZombie PB
KonekoZombie PB
    Bob Long Lives in Vice City Why
  • 968 posts
Posted 25 March 2009 - 09:06 PM
it sounds like you may just need to lube it
Koneko means kitten in Japanese =^.^=
TIMMY MILITIA, **HALO CLAN**, and ze Grammar Nazi's.
#6 Lucas
Lucas
  • 5,342 posts
Posted 25 March 2009 - 09:09 PM
Relube and check o-rings ;)
- Lucas
#7 Camo
Camo
    You cant see me
  • 683 posts
Posted 25 March 2009 - 09:13 PM
If this were PBN you would get the old "HAHAHA thats wat you get for getting an ion" but never here so i would say Lube it up and make shure the O-rings are good mabey take it apart and check for anythig out of the ordanary
Yes I eat paintballs.... What?
Got to love life
#8 MurphMan
MurphMan
    Badass Mod ☺
  • 5,951 posts
Posted 25 March 2009 - 10:15 PM
Cause: Un-lubed or worn o-ring.
Check the following o-rings.
Edited by MurphMan, 25 March 2009 - 10:16 PM.
#9 Squirtle
Squirtle
    How does it feel to get owned by a Pokemon?
  • 252 posts
Posted 25 March 2009 - 10:17 PM
Is the tank still empty or did you fill it and it still leaks? Because sometimes when your air is really low it leaks from the barrel until you fill the tank once again and you shouldn't have a problem.
#10 Devers
Devers
  • 2 posts
Posted 26 March 2009 - 03:23 PM
Alright, thanks everyone for the help.
#11 druid
druid
    Yes, that's me in the Avatar
  • 990 posts
Posted 26 March 2009 - 06:55 PM
Murph has answered it.
but also you said your tank was [almost] empty. That will do it too. When your tank reads bleow 250 psi, it will just vent out the barrel (because gauges just aren't that accurate).
"Political correctness is a doctrine, fostered by a delusional, illogical minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a turd by the clean end."
Ion Owner #12
