Proto pmr eye problems
#1 bmxridersd
bmxridersd
  • 2 posts
Posted 22 March 2013 - 11:36 PM
Ok so I've got an older PMR that I have put a virtue board in. The marker will fire with or without the eyes on but when they are on the board flashes blue for eyes on ball in breach malfunction I try sticking my finger in and out of the breech but no change. I've checked the connection at the board and took the eyes out to check for broken wires but nothing and I've got a good battery
Anyone got any ideas
#2 slinkyaroo
slinkyaroo
  • Root Admin
  • 4,897 posts
Posted 23 March 2013 - 09:05 AM
If everything is clean then new eyes. There's a reason they're in rebuild kits. Check for pinching or ribbon cracks.
Wipe them down with rubbing alcohol and try again first.
#3 bmxridersd
bmxridersd
  • 2 posts
Posted 23 March 2013 - 06:35 PM
I checked the ribbon and it looked fine but ill check again
