Axe won't pressurize. Need help fast!
12 replies to this topic
#1 Poopfairy35
Poopfairy35
    Providing useless insights here since 2013
  • 432 posts
Posted 02 April 2013 - 06:42 PM
So just took my axe apart to clean it, (no I didn't mess with the reg) & when I gassed it up the gauge didn't budge & the gun won't fire. My tank is filled to 3000 psi. Need help fast!
I am a raccoon.
  • 22,435 posts
Posted 02 April 2013 - 06:43 PM
Did you flip the on/off lever on the bottom of the ASA?
#3 Poopfairy35
Poopfairy35
  • 432 posts
Posted 02 April 2013 - 06:48 PM
Yeah. Air does come out when I flip the lever back.
I am a raccoon.
#4 kingJurzy
Posted 02 April 2013 - 06:55 PM
Talk it apart again. Did you take off the reg at all?
#5 Poopfairy35
Poopfairy35
  • 432 posts
Posted 02 April 2013 - 06:57 PM
Yeah, I did take it off the gun to wipe paint off of it because the gauge got shot a bunch.
I am a raccoon.
#6 kingJurzy
Posted 02 April 2013 - 07:02 PM
Take it off then put it back on, make sure you have the oring on there and make sure that the transfer hole gets lined up in there.
#7 Poopfairy35
Poopfairy35
  • 432 posts
Posted 02 April 2013 - 07:05 PM
Tried it, it didn't work. Thanks anyway.
I am a raccoon.
#8 kingJurzy
Posted 02 April 2013 - 07:08 PM
Can you just take the marker completely apart?
Maybe your gauge is broken because it does not give you a pressure.
#9 Poopfairy35
Poopfairy35
  • 432 posts
Posted 02 April 2013 - 07:15 PM
Ok, I just took it apart & took the reg off, tried to gas it up, but air won't come out of the regulator with it off of the gun.
I am a raccoon.
#10 Tick
Tick
  • 1,197 posts
Posted 02 April 2013 - 07:23 PM
Change Battery, Reset to Stock Settings, Try adjusting the velocity for more air input
#11 Poopfairy35
Poopfairy35
  • 432 posts
Posted 02 April 2013 - 07:38 PM
Thanks, it turns out my reg screw was just backed out to zero.
I am a raccoon.
#12 XGC_Cheevo
XGC_Cheevo
    Pod Scalping You
  • 3,026 posts
Posted 02 April 2013 - 09:26 PM
So.... You've got it working again? If yes, glad to hear.
#13 kingJurzy
Posted 02 April 2013 - 09:51 PM
lol
Glad to hear it is working again.
