infamous bolt problems
5 replies to this topic
#1 marceldacs
marceldacs
  • 1,072 posts
Posted 06 April 2013 - 06:31 PM
Recieved the infamous bolt yesterday. 2 weird things are happening. I know it is the bolt since when i install my boss bolt v2, there are zero problems.
1. Pressure is at 150, dwell is at 5. THere is A LOT of blow back. With the two ball in the feed neck test, the top ball will shoot out of the feed neck at least 6 feet.
2.When i use the large rear oring for extremely brittle paint, the gun does not even cycle. The pressure would be at 150, dwell at 10ms, using long spring, and when i press the trigger, all i hear is a louder than normal solenoid click when there is air inside the axe. Something very strange is happening so please help me.
#2 TippmannPlayer97
TippmannPlayer97
  • 1,942 posts
Posted 06 April 2013 - 06:48 PM
theres another post already like this. infamous bolt is bad, and you should feel bad. dont bother upgrading bolts, doesnt do much. sell the infamous bolt if you can. use stock and sell the boss, or use the boss and dont upgrade any more internals, besides maybe a redline if you dont have one/are interested in one.
lol i didnt realize you were the same guy
#3 kingJurzy
Posted 06 April 2013 - 06:56 PM
The Boss and Lurker bolts contribute to a HUGE efficiency gain and makes the marker smoother and quieter.
I'd get a new trigger and boss bolt over a Redline.
#4 TippmannPlayer97
TippmannPlayer97
  • 1,942 posts
Posted 06 April 2013 - 07:00 PM
meh, efficiency shmeficciency, if i can shoot 6 pods im happy. and why change the trigger on the axe? its just fine
#5 kingJurzy
Posted 06 April 2013 - 07:08 PM
Because with a Critical trigger it shoots like hot sex.
#6 TippmannPlayer97
TippmannPlayer97
  • 1,942 posts
Posted 06 April 2013 - 07:17 PM
fair enough. how much do those cost? for more than 25 i dont think it would be worth it since the stock is great. just my opinion
