Still having problems with my infamous intimidator
14 replies to this topic
#1 MedevilMIke
MedevilMIke
  • 351 posts
Posted 14 April 2013 - 03:37 PM
I've been working on this for a very long time and for the life of me I can't figure out why I can't get over 175 FPS. I've changed every O ring and lubed it with dow 55 completely. I just can't figure out what's going wrong, the regulator is a Bob Long 360. I have adjusted the LPR and the HPR several times and nothing, I have even gone to 85 PSI on the LPR and that didn't work. Any help would be greatly appreciated.
#2 slinkyaroo
slinkyaroo
  • Root Admin
  • 4,897 posts
Posted 14 April 2013 - 05:32 PM
Any leaks? Is there orings on the bolt? Did you check your dwell? New battery?
Lpr doesn't project the ball. Turn down the lpr and up the main reg.
#3 MedevilMIke
MedevilMIke
  • 351 posts
Posted 14 April 2013 - 06:15 PM
no leaks at all, yes there is O-rings on the bolt, new battery, dwell is at 8
#4 kingJurzy
Posted 14 April 2013 - 06:43 PM
hose kink?
#5 slinkyaroo
slinkyaroo
  • Root Admin
  • 4,897 posts
Posted 14 April 2013 - 06:44 PM
Did you rebuild the regs?
#6 MedevilMIke
MedevilMIke
  • 351 posts
Posted 14 April 2013 - 07:11 PM
no kinks in the hose, no I did rebuild the 360 reg ( it came off my marq and it was working great ) as far as the other one yes I did rebuild it.
#7 TippmannPlayer97
TippmannPlayer97
  • 1,942 posts
Posted 14 April 2013 - 07:34 PM
ahh timmies.... unreliability at its finest. on topic: sounds like an issue with the velocity adjuster directly. dont know a hell of alot about those beyond the unreliabilty, but my alpha blacks velocity adjuster is wierd and is hot or miss on its ability to adjust
#8 Pump Player
Pump Player
    Voted techpb's #1 sloth
  • 929 posts
Posted 14 April 2013 - 09:08 PM
Have u checked the solenoid? I'm not an expert on poppets but I remember how older eclipse egos and eteks used to have burst and cause velocity issues
#9 CPS
CPS
  • 1,436 posts
Posted 14 April 2013 - 09:11 PM
those were the QEVs
#10 MedevilMIke
MedevilMIke
  • 351 posts
Posted 14 April 2013 - 09:19 PM
no I haven't done the noid.
#11 fatalreaction
fatalreaction
  • 258 posts
Posted 15 April 2013 - 02:29 AM
is your ram cap tight? is it adjustable? if so is it adjusted properly?
#12 510waffles
510waffles
  • 1,767 posts
Posted 15 April 2013 - 03:12 AM
is your gauge working properly?
make sure your solenoid is working. see if you can find another friends solenoid that you can use
if not, send it to blast
Edited by 510waffles, 15 April 2013 - 03:12 AM.
#13 awesompants
awesompants
    My pants are awesome.
  • 758 posts
Posted 15 April 2013 - 08:07 PM
Wut. Have you ever owned, or even shot a Timmy? There is no velocity adjuster. Just the regulators. And Bob Longs are extremely reliable. Stop going on threads and talking about things you know very little about.
#14 510waffles
510waffles
  • 1,767 posts
Posted 15 April 2013 - 10:20 PM
Child please
#15 MedevilMIke
MedevilMIke
  • 351 posts
Posted 15 April 2013 - 10:37 PM
Child please
This is a quote from Mike himself " Pound for Pound, the Alias is the BEST paintball gun on the market right now " and if I'm not mistaken that is a intimidator.
sorry 510waffles this wasn't directed towards you
Edited by MedevilMIke, 15 April 2013 - 10:41 PM.
