Cutting grips for OLED
8 replies to this topic
#1 BurningPlaydoh
Posted 22 April 2013 - 11:16 PM
The short and sweet: I like OLED boards, I hate Tadao panel grips. Does anyone know of a tutorial for cutting wraparound grips for an OLED? Its specifically for G6R wraparound grips on a Vic V1 with a Tadao OLED.
#2 Panda Man
Panda Man
  • 4,315 posts
Posted 22 April 2013 - 11:20 PM
just get an razor blade, a pair of steady hands and start cutting. Make sure you measure twice and cut once... ;) Just gently cut away till your exact measurements are the ones you want.
#3 BurningPlaydoh
Posted 22 April 2013 - 11:26 PM
My problem is how I deal with the plastic backing and cover the hole to keep paint out. I figure a dremel will solve the first problem, but would something like a thin piece of lexan put in place with epoxy work to cover with?
#4 Panda Man
Panda Man
  • 4,315 posts
Posted 22 April 2013 - 11:29 PM
if you got Surgical hands you maybe able to cut a notch out for a VERY small piece of plexi like window.
#5 BurningPlaydoh
Posted 22 April 2013 - 11:31 PM
I was thinking take some material off the inside and have it overlap and epoxy that on. IDK about the fit though, I'd need to find something transparent and thin enough.
#6 Panda Man
Panda Man
  • 4,315 posts
Posted 22 April 2013 - 11:34 PM
^plus the material you use for the window may "sweat" and fog up on hot days.
#7 SynystrAssassin
SynystrAssassin
    Flawless is a Habit
  • 1,180 posts
Posted 22 April 2013 - 11:43 PM
Cut the window out of the tadao grips?
#8 Cheeks
Cheeks
  • 479 posts
Posted 23 April 2013 - 12:41 AM
Yeppers! Or I would just find some random plastic around the house of the right thickness and clearity
#9 ccseancc143
ccseancc143
    i'm cool with that
  • 529 posts
Posted 23 April 2013 - 03:49 PM
My friend did this with his etek 3 grips. He cut out the window with a exacto knife and they took that plastic packaging that is impossible to cut with scissors and cut a small portion and just put it under the grips and when he screwed the grips back on the plastic stayed in place.
