GEO2 Solenoid gasket issue
No replies to this topic
#1 AJ1337
    MEOW :3
  • 608 posts
Posted 07 May 2013 - 04:17 PM
I'm having some issues with replacing my Geo2 solenoid's gasket seal, the thing is, the stock one from the factory came with the filter preinstalled (also with a sort of cut-out for the filter screen) but the new replacement i recieved has the filter completely separated( a piece of metal screen with a sort of cupped shape to it), and either way i place it (whether it be filter below gasket with the cup curve facing downward or upward) it seems to not fit correctly with the marker body as the solenoid itself does NOT fit flush with the body (even when not aired up) and when i air my marker up, after 200 shots it starts to progresively leak worse and worse until it's imposible to play with the marker.
service centers here in Venezuela are horseshit so i don't count on them for help.
