need some help
#1 jay d.
jay d.
  • 5 posts
Posted 10 June 2013 - 11:23 PM
Ok so i bought a cf boomstick for my dp g4, im hooking paint pretty bad after about 15 ft so i think my red legion may be the reason. I have the .688 15 inch, cam anyone give me a small list of specific paint i can use for it, or i should say a list of cheap and accurate paint.
#2 paintballguy2255
  • 2,027 posts
Posted 11 June 2013 - 08:38 PM
Thereisn't really any consistently good and cheap paint out there.My proshop recently started selling Red Legion,and it has been shooting lazors for me.And .688 is a fairly large bore,most paint these days is under .685 or so.So I would suggest just buying higher-quality paint,and making sure you have a clean barrel.
#3 Toxin PB
Toxin PB
    California Baller
  • 567 posts
Posted 11 June 2013 - 10:14 PM
Was your barrel dirty? I've shot some pretty bad paint ( just ask Garibean ) and if my barrel is swabbed out and not covered in paint it flys strait enough
