Problem with eyes
14 replies to this topic
#1 TheDirtyGardner
TheDirtyGardner
  • 5 posts
Posted 14 June 2013 - 05:10 PM
I got a Valken Proton last week and i havent even fired it yet. i obviously have turned the eyes on and off and tried all the modes just with the eyes off so the solenoid clicks to make sure everything works. 2 days ago i turned it on again and the eyes were on and i tried to pull the trigger a few times and the solenoid clicks but the red light blinks 3 times and then stays solid and that means the breach isnt clear. i cleaned it many times and it still isnt working. please help im planning to finally use it this tuesday. Any Thoughts?
#2 OBF
OBF
  • 1,345 posts
Posted 14 June 2013 - 05:20 PM
The eyes were on and the solenoid was clicking?
My feedback: http://www.techpb.co...331&hl=feedback
10/0/0
#3 Panda's Revenge
Panda's Revenge
  • 3,495 posts
Posted 14 June 2013 - 05:23 PM
Looks like you need to see an optometrist :dodgy:
Might be a programming issue, did you buy it at a store or online?
#4 asthmaticrhino
asthmaticrhino
  • 1,159 posts
Posted 14 June 2013 - 06:03 PM
Is your bolt in the foward position?
#5 NoLimitsOnLife
NoLimitsOnLife
    Patience is a Virtue, and my board is broken
  • 1,388 posts
Posted 14 June 2013 - 07:22 PM
im curious to know why the solenoid was clicking with the eyes on. If that's true and the breech was clear then there's a programming issue. as for your current issue, i would change the battery and see if that fixes it.
Setup: System X NME LE, Dye Rotor, Guerrilla Air 88/4500 Myth G2
MARYLAND BALLERS FTW
Feedback:9/0/1
#6 NBTIppy
NBTIppy
    Sterling
  • 2,479 posts
Posted 14 June 2013 - 08:47 PM
have you taken the gun apart at all? maybe pinched a wire in the process?
#7 TheDirtyGardner
TheDirtyGardner
  • 5 posts
Posted 15 June 2013 - 10:10 AM
I bought it online and the solenoid is clicking with the eyes on i havent shot it or take. It apart and the bolt is back and i tried changing the battery already
#8 kingJurzy
Posted 15 June 2013 - 11:34 AM
No one to thought to reset the board?
#9 TheDirtyGardner
TheDirtyGardner
  • 5 posts
Posted 15 June 2013 - 10:42 PM
I changed the battery again and it worked for about 3 hours then i checked again and it didnt work
#10 Panda's Revenge
Panda's Revenge
  • 3,495 posts
Posted 16 June 2013 - 12:47 AM
Okay if resetting the board doesn't work call up Valken and ask if you can RMA it back
#11 TheDirtyGardner
TheDirtyGardner
  • 5 posts
Posted 16 June 2013 - 04:30 PM
How do you reset the board?
#12 TacticlTwinkie
TacticlTwinkie
    *insert witty title*
  • 3,974 posts
Posted 16 June 2013 - 04:37 PM
It shouldn't click with the eyes on unless you stick something in the breech. It sounds like its working fine. Try it with air and paint and see if it works. Some guns have a delayed fire with the eyes (Blackheart board) where you can hold the trigger to make it fire with the eyes still on. Perhaps the proton has something like that?
#13 kingJurzy
Posted 16 June 2013 - 04:39 PM
There is an owner's manual that comes with the marker and it is for this reason.
#14 TheDirtyGardner
TheDirtyGardner
  • 5 posts
Posted 16 June 2013 - 05:06 PM
It doesnt tell you how to reset the board actually
#15 kingJurzy
Posted 16 June 2013 - 08:01 PM
Take pics of the board for me, all around the board.
Also some boards reset after you have the battery out for a while. Take out the battery and leave it out for 20 minutes. Press the power button at 10 minutes.
