Help with buying first gun
31 replies to this topic
#1 Paintballwashington
Paintballwashington
  • 36 posts
Posted 16 June 2013 - 02:48 PM
I need help with buying my first gun.well iam kinda leaning to a spyder fenix or pilot cause a friend has an older pilot that it pretty sweat .i just need an electric gun that is better than a tippmann 98 rental at the field.I NEED NOTHING FANCY over $150.i will also buy used
#2 NICKMISIU
NICKMISIU
    Smartass of forever
  • 328 posts
Posted 16 June 2013 - 03:03 PM
Do you have a good mask, tank and hopper? If not, get those first, in that order. Get the best mask you can afford, nothing under $70, like the proflex, flex 8, profiler, or grillz for the cheaper side. Then get a used 4500 tank, maybe even if its out of hydro for $70. Save up for a hopper, and then get a gun.
Doesn't matter what gun you have, how old you are, what paint you shoot, who your up against, how bad of a day you had... All that matters is that your playing paintball now.
#3 Paintballwashington
Paintballwashington
  • 36 posts
Posted 16 June 2013 - 03:25 PM
I only go 3 times a year .i don't need a tank
#4 Paintballwashington
Paintballwashington
  • 36 posts
Posted 16 June 2013 - 03:27 PM
And my mask is fine it doesn't fog
#5 BurningPlaydoh
Posted 16 June 2013 - 04:01 PM
Used Ion: $80
Also how much did your mask cost? Depending on that I would still say get a new one first.
#6 NICKMISIU
NICKMISIU
    Smartass of forever
  • 328 posts
Posted 16 June 2013 - 05:17 PM
If you only go 3 times a year, its a waste of money to get your own gun...
#7 Paintballwashington
Paintballwashington
  • 36 posts
Posted 16 June 2013 - 06:17 PM
Well this year I might go more if I get a gun
#8 NICKMISIU
NICKMISIU
    Smartass of forever
  • 328 posts
Posted 16 June 2013 - 06:30 PM
Get other things first.
#9 Orange Chicken
Orange Chicken
    TechPB's Most Annoying member
  • 5,611 posts
Posted 17 June 2013 - 03:00 PM
Yeah, good, high end mask first. Then tank, then loader, THEN marker.
And the mask will be well worth it. I have friends who have 130 dollar masks, but nothing else, and go bi annually on our organized days, and seem to be much more satisfied with at least not having to worry about anything regarding their mask, which is really the only thing you need to play.
#10 JoseFuentes
JoseFuentes
  • 13 posts
Posted 17 June 2013 - 04:21 PM
http://www.punishers...-gun-black.aspx
Cheap refurbished Smart Parts Vibe
#11 Praetorian
Praetorian
    Skill? Where can I buy that?!
  • 1,273 posts
Posted 17 June 2013 - 04:31 PM
if you don't mind a Hell of a learning curve on maintenance look into a used Autococker, they run around $100 and work Fantastic as a normal Rec. Ball mechanical gun.
#12 Paintballwashington
Paintballwashington
  • 36 posts
Posted 17 June 2013 - 08:26 PM
Are sp refurbished vibe worth it.and autocockers seem really complicated
#13 Orange Chicken
Orange Chicken
  • 5,611 posts
Posted 17 June 2013 - 08:55 PM
Yes of course they are worth it! eNVy's are one of the top recommended markers in the sub-200 dollar price range, and the Vibe is the exact same thing, albeit it an older model.
#14 Paintballwashington
Paintballwashington
  • 36 posts
Posted 17 June 2013 - 09:14 PM
What about the autocockers though
#15 Paintballwashington
Paintballwashington
  • 36 posts
Posted 17 June 2013 - 11:42 PM
Made my mind its gonna be a vibe .thank you guys
#16 Paintballwashington
Paintballwashington
  • 36 posts
Posted 17 June 2013 - 11:46 PM
Also iam getting around $100 hopper looking at an empire scion ,just anything not complicated just tap a button and go
#17 Orange Chicken
Orange Chicken
  • 5,611 posts
Posted 17 June 2013 - 11:59 PM
Go used then. Look for a superloader. Rotors can be easily found for 100 bucks.
#18 Wolfe
Wolfe
  • 813 posts
Posted 18 June 2013 - 09:21 AM
http://www.punisherspb.com/smart-parts-vibe-refurbished-paintball-gun-black.aspx
Ordered on of these for my son over the weekend.
But, no doubt. Even if you're only going a few times a year. Having your own mask will make a world of difference. May even inspire you to go more often.
#19 Ninjaafro
Ninjaafro
  • 246 posts
Posted 18 June 2013 - 09:53 AM
Get the vibe. If you are looking for a loader around 100 get the pinokio
#20 Paintballwashington
Paintballwashington
  • 36 posts
Posted 18 June 2013 - 11:04 AM
How much better is it than the scion
#21 Wolfe
Wolfe
  • 813 posts
Posted 18 June 2013 - 11:27 AM
I wouldn't say the Pinokio is better than the Scion. If you're buying new, then the Pinokio will be the cheapest. However, the Rotor, Scion, Pinokio and a bunch of others can be had used around the 100.00 mark. Personally, I'd go with the Rotor.
#22 Ninjaafro
Ninjaafro
  • 246 posts
Posted 18 June 2013 - 11:43 AM
My friend has a scion and it looks like a halo but feeds like a z2. It is hella hard to clean. The pinokio is just as fast and super easy to clean. I'm getting a pinokio in a few weeks. The only thing about e pinokio is that it looks kinda bulky. Hope this helped.
#23 TechPB-Willie
TechPB-Willie
    The man behind the scene.
  • Root Admin
  • 2,720 posts
Posted 18 June 2013 - 12:26 PM
I would recommend a mask first and then is you still need a marker get the Vibe aka eNVy. Depends on the manufacturer what the name is. But it is the best option for an inexpensive marker.
#24 Paintballwashington
Paintballwashington
  • 36 posts
Posted 18 June 2013 - 02:39 PM
Thank you Willie .and it turns out I found a 06 etek for $200 super nice condition with hyper 3 reg.
And I think I might just get a jt mask like a proflex
#25 Paintballwashington
Paintballwashington
  • 36 posts
Posted 18 June 2013 - 03:10 PM
Hmm now what todo pinokio or used rotor. I think I might go used rotor
#26 Ninjaafro
Ninjaafro
  • 246 posts
Posted 18 June 2013 - 04:06 PM
Rotor for speed, durability, and look. Pinokio for battery efficient, more paint storage, and price
#27 Orange Chicken
Orange Chicken
  • 5,611 posts
Posted 18 June 2013 - 04:34 PM
Go for the Rotor if you can get it used for a good price. The pinokio is only worth it if you want that extra amount of paint to use.
#28 Paintballwashington
Paintballwashington
  • 36 posts
Posted 18 June 2013 - 08:39 PM
Never mind the guy I'm buying the etek from also has a prophecy for sale for $65 so I'm gonna buy that with the gun
#29 jakesd1995
jakesd1995
  • 142 posts
Posted 19 June 2013 - 08:42 PM
The Invert Halo Too is 84 on ANSgear.com or a Proto Primo, also look into some 2010 Empire pants, best pants ever!
#30 Paintballwashington
Paintballwashington
  • 36 posts
Posted 19 June 2013 - 09:41 PM
No thank u I don't want a shake and bake hopper.but if I don't have enough money I might buy a halo too
#31 Jalen
Jalen
    Resident Psychopath
  • 1,613 posts
Posted 20 June 2013 - 12:13 AM
If you only go three times a year I don't know why you're even bothering shopping for your own gear, and as for going more often if you had your own gear... why not just use that money to go play more paintball in the first place?
#32 Paintballwashington
Paintballwashington
  • 36 posts
Posted 20 June 2013 - 11:26 AM
Ya I'm goin paintballing way more this year .i might even go to ninjaball this year if I can get my friends to go
