Axe regulator major problem
5 replies to this topic
#1 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 22 June 2013 - 07:12 PM
So when I air up my axe the needle would go straight to 300 psi even when you take off the pressure adjuster screw! Is it broken and could I fix it and once it hit over 300 psi it will start to leak from where the tank is screw in.
#2 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 22 June 2013 - 07:15 PM
Here is the video of it:
#3 andrewthewookie
  • 22,405 posts
Posted 22 June 2013 - 08:40 PM
Reg creep, you'll need to contact Empire about getting it fixed.
http://www.paintball...php/contact-us/
#4 Soundwave
Soundwave
    I win paintball.
  • 661 posts
Posted 22 June 2013 - 08:57 PM
Just to emphasise what Andrew said, you can't fix this. You need to send the marker to Empire.
#5 Hyrinmaru
Hyrinmaru
  • 176 posts
Posted 22 June 2013 - 10:12 PM
Is it the marker or the reg?
#6 kingJurzy
Posted 22 June 2013 - 10:13 PM
Reg
