gear for my younger cousin
18 replies to this topic
#1 klown
klown
    Gamer and Woodsballer
  • 278 posts
Posted 26 June 2013 - 06:13 PM
So I am not a newbie but he is and I wanted to get him his own basic gear. He helped me pick out (and by helped me pick out, I mean he picked out) the gear. He does not play as often as I do, so the gear is pretty basic and I would like opinions on the set up.
Marker:http://www.ansgear.c...ouspe1green.htm
Mask:http://www.ansgear.c...roflexblack.htm
Tank:http://www.ansgear.c...484500&CartID=5
Loader:http://www.ultimatep...ion-loader.aspx
Pack:http://www.ansgear.c...4BLACK&CartID=3
And on an off note does anyone know the oring size for the raps asa?
Primary-SP1 Blackheart with RAPS II asa                Back Up/Loaner-Tippmann Alpha Black
ANS 68/4500                                                              Guerrilla Air 48/3000
GXG 4+5 Pod Pack-Camo                                         4+5 orGxG  4+1
FASTA 18v LED-Smoke                                             JT Shake 'n Bake
Proto Switch FS-Camo                                               Switch FS or Tippmann Mask
#2 PatsPotatoVan
PatsPotatoVan
  • 140 posts
Posted 26 June 2013 - 06:49 PM
I would rather him get like an Enmey or Envy. The Enmy since he won't play often or the Envy cause it's electric, same price as the E1 but has a clamping feedneck. Also a Proto Primo would do a good job on either of those and doesn't require batteries. Everything else is fine :tup:
Player
Photographer
Referee
#3 klown
klown
  • 278 posts
Posted 26 June 2013 - 07:09 PM
Thanks, Personally I had a bad experience with GoG. He is going to he held the E1 at a local shop as well as a rail and liked the E1 because he has smaller hands. I will see if he wants to look into something else though. I was also thinking of a used ion w up if I could find one
#4 get.lit.up!
get.lit.up!
  • 3,777 posts
Posted 26 June 2013 - 08:15 PM
Personally:
marker: GoG eNVy or eNMEy (I'm more in favor of eNMEy)
Mask: preference (maybe JT with event ears vs profilers? imo)
Tank: Empire will work, but if can pony up the extra $20, ninja is the way to go
Hopper: Used revvy is Ok too, used halos, used non-z2 prophecies
Pack: preference, but also consider : http://www.ansgear.c...tpack25camo.htm
any thoughts to padding or the sort?
#5 klown
klown
  • 278 posts
Posted 26 June 2013 - 08:32 PM
Personally:
I brought that up to him but he doesn't want any pads. Kid is more hard headed  than I am lol. I was thinking an electro to start with that way he wouldn't have to upgrade when we start playing tournaments
Edited by klown, 26 June 2013 - 08:33 PM.
#6 III Kezia III
III Kezia III
    Lulzjustbeingacat :D
  • 878 posts
Posted 26 June 2013 - 08:40 PM
id opt for a blitz only because i dont feel like the E1 is worth the 200 you spend for it. doesnt come with a clamping feedneck and has a useless 30 bps full auto mode that you cant use.
#7 get.lit.up!
get.lit.up!
  • 3,777 posts
Posted 26 June 2013 - 08:52 PM
Personally:
How invested is your brother currently? Might as well over the top if you ask me on gear if he is invested that much.
#8 klown
klown
  • 278 posts
Posted 26 June 2013 - 09:41 PM
Personally:
It will be a couple years before we start playing tournaments,  I want him to get a few years experience first. He has no gear of his own right now but he is hooked and I told him if it was alright with my aunt and uncle and he got good grades I would get him gear
#9 Wolfe
Wolfe
  • 813 posts
Posted 26 June 2013 - 10:07 PM
Personally:
A couple of slides and he'll be begging for pads. lol
#10 klown
klown
  • 278 posts
Posted 27 June 2013 - 08:45 AM
Personally:
Yup lol
#11 Bunneh
Bunneh
    Weekend Baller
  • 145 posts
Posted 27 June 2013 - 11:21 AM
Really the only thing I see wrong with it is... pants. Has he ever tried doing some intense slides before. Could just be that I have a knee disease (Osgood Schaltter) but getting just plain old volleyball kneepads made a HUGE difference.
He must have some real small hands if he needs that :/
#12 klown
klown
  • 278 posts
Posted 27 June 2013 - 11:38 AM
He doesn't have terribly small hands he just like a tight feel
#13 Orange Chicken
Orange Chicken
    TechPB's Most Annoying member
  • 5,611 posts
Posted 27 June 2013 - 01:54 PM
I say eNMEy or eNVy for the marker.
Mask? Go with the profilers over the proflexs
Tank? Any one works, you should probably go with a higher end carbon fiber for him.
Loader? Go with a halo, from the money you saved from going to the eNMEy.
Pack? At least get a cheaper end empire or NXe pack, don't burden him with a cheap quality GxG pack.
See the eNMEy is underestimated. It should shoot fast enough and well enough to be mmore than sufficient for recplay, even if it is airball. I also recommend that you don't burden him with bad quality gear that may become useless very soon. A halo is a good backup loader, but a revvy isnt.
#14 klown
klown
  • 278 posts
Posted 27 June 2013 - 05:34 PM
I may just do that then. I also may not have to buy him a loader as I will be upgrading from my 18v fasts
#15 klown
klown
  • 278 posts
Posted 27 June 2013 - 05:52 PM
So now he wants a G1 Blackheart
#16 get.lit.up!
get.lit.up!
  • 3,777 posts
Posted 27 June 2013 - 09:28 PM
If you wan to do tourneys for sure go for the eNVy as the marker.
#17 klown
klown
  • 278 posts
Posted 27 June 2013 - 09:52 PM
He wants to just play woods because that is all that is around us. He doesn't want to play air ball/tournaments
#18 Orange Chicken
Orange Chicken
  • 5,611 posts
Posted 27 June 2013 - 09:55 PM
Well just skip that and get him either an eNMEy or an eXTCy, both are less than the G1 with blackheart, still better preformance.
#19 klown
klown
  • 278 posts
Posted 27 June 2013 - 10:18 PM
Will do. He likes the look of the eXTCy but also loves my sp1 blackheart. I don't really care what he wants to play to be honest as long as he is having fun
