Dangerous Power Threshold - Severe boltstick problem
Has NEVER shot a ball!
9 replies to this topic
#1 Sexypaki55
Sexypaki55
  • 403 posts
Posted 01 July 2013 - 02:31 PM
FIXED IT.. with this
So I'm guessing this is boltstick. A friend of mine gave the gun to me a couple of days ago after trying for months to get it working. He never did.
Fresh Battery CHECK
Max Dwell CHECK
Bolt lubed (DOW55) CHECK
Shim stack correct CHECK
I put the bolt in forward position before airup CHECK
Enough HPR pressure CHECK
Enough pressure in tank CHECK
Here's a video
Edited by Sexypaki55, 02 July 2013 - 06:53 AM.
  • 22,405 posts
Posted 01 July 2013 - 02:34 PM
Avoid Dow 55 on spools, especially blow-forwards like the Threshold. It's thicker, and can swell o-rings. You'll want to use Dow 33 or one of the many paintball derivatives of Dow 33.
#3 Sexypaki55
Sexypaki55
  • 403 posts
Posted 01 July 2013 - 02:36 PM
Allright, the problem existed before I lubed it though.
#4 Praetorian
Praetorian
    Skill? Where can I buy that?!
  • 1,273 posts
Posted 01 July 2013 - 02:38 PM
possibly to much lube, your settings are still out of whack.
Make sure it's lightly lubed not overly lubed. Also make sure all the o-rings are in working order and one hasn't be torn.
#5 Sexypaki55
Sexypaki55
  • 403 posts
Posted 01 July 2013 - 06:13 PM
Cleaned of the DOW, and put a SLIGHT coat of Dye Slick on the bolt. I also replaced the inner O-ring, it had some wear. Still, it seems to stick like hell. As you saw in the video, it easily shoots back after airup, but nothing gets the bolt forward.
Im suspecting this has nothing to do with lube..
#6 andrewthewookie
  • 22,405 posts
Posted 01 July 2013 - 06:19 PM
The inner o-ring, as in the bolt plug o-ring?
#7 Sexypaki55
Sexypaki55
  • 403 posts
Posted 01 July 2013 - 06:30 PM
That one.
https://photos-4.dro...k?size=1280x960
Edited by Sexypaki55, 01 July 2013 - 06:31 PM.
#8 andrewthewookie
  • 22,405 posts
Posted 01 July 2013 - 06:33 PM
That link is giving me an error.
#9 Sexypaki55
Sexypaki55
  • 403 posts
Posted 01 July 2013 - 06:44 PM
sorry, here you go.
Edited by Sexypaki55, 01 July 2013 - 06:45 PM.
#10 Sexypaki55
Sexypaki55
  • 403 posts
Posted 01 July 2013 - 06:47 PM
Edited by Sexypaki55, 02 July 2013 - 06:52 AM.
