First gun help
26 replies to this topic
#1 TheMajorFB
TheMajorFB
  • 108 posts
Posted 09 July 2013 - 12:04 AM
I am looking for my first gun and i am still trying to figure out what i want. these are my choices and why i want it. i want to buy new.
2011 proto rail. soft on paint, quiet, smooth shot.
Gog extcy, case and smooth shot, on off asa
Dangerous power g4, looks, on off asa, low rise clamping feedneck
gog envy, case, price
azodin zenith is it any good or just skip it.
I play mostly airball and speedball but would like to play woodsball ever once and a while.
any other choices would be great but that is all i can think of.
any help would be great and pls dont just say that is better or this is better please give reasons.
#2 bassfisher
bassfisher
  • 2,100 posts
Posted 09 July 2013 - 12:08 AM
I would get the rail, they are great shooters. It has a hyper 3 reg, which is the same one off of a DM13. It also uses the eye pipe system like other high end dye guns. The only think I don't like about it is the efficiency... Or lack thereof. At most you'll be getting about 5-6 pods off of a 68/4500.
Also, what other gear do you have?
Edited by bassfisher, 09 July 2013 - 12:12 AM.
Carolina Riot Scenario Team
#3 TheMajorFB
TheMajorFB
  • 108 posts
Posted 09 July 2013 - 12:18 AM
i got a used dye rotor and i dont have a tank yet playing with some guys that have tanks that i can use till i have some more money and but im looking at either a 48/4500 or a 50/4500 im 13 and shorter like 5'2 so i want a small tank have used a 68/4500 and i found that to be a bit big
#4 SplatSplatOrange
SplatSplatOrange
  • 507 posts
Posted 09 July 2013 - 12:25 AM
Rail or the extcy both are great guns and about the tank both 48and 50 are great for shorter players, pick with ever one feels the best to you
<p>G6R Red/black Ninja slp 45/45 Grillz Spire
Member of Chi-Town-Rampage
#5 TheMajorFB
TheMajorFB
  • 108 posts
Posted 09 July 2013 - 12:34 AM
What is your choice I may just literally flip a coin
#6 bassfisher
bassfisher
  • 2,100 posts
Posted 09 July 2013 - 12:36 AM
What mask do you have? An added bonus I forgot to mention about the rail is that the maintenance is really simple and pretty easy.
#7 SplatSplatOrange
SplatSplatOrange
  • 507 posts
Posted 09 July 2013 - 12:47 AM
I'd go extcy little more Efficient and has a on /off Asa but both are great choices
Both guns are really easy to maintain
#8 tallsmallboy44
Posted 09 July 2013 - 12:52 AM
The eXTCy and Rail will shoot very similar. You can literally pick off of looks, what comes in the box, or the features that are more important to you. The best option would be to hold both if you can.
#9 TheMajorFB
TheMajorFB
  • 108 posts
Posted 09 July 2013 - 01:06 AM
I have a jt spectra mask thermal love it I double strapped it :-) I can't hold both how often do you have to maintain a regulator
#10 ForcePlate
ForcePlate
  • 74 posts
Posted 09 July 2013 - 01:11 AM
I would watch the reviews on the GOG extcy and the Proto rail on techpb's youtube channel and see witch one in your opinion is better. Also if you see someone at the field with with either gun ask them if you can shoot it to get a feel of what you want. Hope this helped and welcome to paintball  :)
#11 TheMajorFB
TheMajorFB
  • 108 posts
Posted 09 July 2013 - 01:19 AM
I think my mind is set on the gog extcy because of the on off asa trigger looks better better feed neck awesome case just looks awesome so I think I have made up my mind
#12 ForcePlate
ForcePlate
  • 74 posts
Posted 09 July 2013 - 01:33 AM
Excellent choice!
#13 Wolfe
Wolfe
  • 813 posts
Posted 09 July 2013 - 08:51 AM
I have a weakness for Protos, but the GoG has the advantages with the ASA and feed neck. Didn't stop me from buying a Rail though.
#14 TheMajorFB
TheMajorFB
  • 108 posts
Posted 09 July 2013 - 09:23 AM
What is so bad with the dangerous power g4 or has everything clamping feedneck on off asa great looks everything why does everybody hate th
#15 tallsmallboy44
Posted 09 July 2013 - 11:42 AM
Nothing. Most of the people who dislike it are bandwagoners and have never even held the marker. It's not a bad marker, there are just "better" options.
#16 BurningPlaydoh
Posted 09 July 2013 - 05:44 PM
They can have issues straight out of the box like leaking macro fittings and they are less efficient and not as smooth as other markers in the price range. They still get the job done at the end of the day if you know how to care for them.
#17 TheMajorFB
TheMajorFB
  • 108 posts
Posted 09 July 2013 - 06:59 PM
can you increase the rate of fire on the proto and how is the trigger for semi auto play
#18 SplatSplatOrange
SplatSplatOrange
  • 507 posts
Posted 09 July 2013 - 07:04 PM
both guns have different modes the extcy has more, the trigger is completely objective
and you cant maintain the reg on the extcy yourself...
#19 TheMajorFB
TheMajorFB
  • 108 posts
Posted 10 July 2013 - 10:39 AM
what should i get a used etek 3 lt for $260 or a used dangerous power g5 for $225
#20 BurningPlaydoh
Posted 10 July 2013 - 11:05 AM
The Etek is a much better value, I would go with that for sure.
#21 bassfisher
bassfisher
  • 2,100 posts
Posted 10 July 2013 - 12:29 PM
yes, there is a way to increase the max rof, but I believe the board is capped at 17. The trigger isn't that bad. Its not amazing, but its not bad.
#22 MikeBlahBlah
MikeBlahBlah
  • 43 posts
Posted 10 July 2013 - 10:44 PM
Yeah, You will probably never end up using 17bps though. Most fields have a cap at 12.5 - 15 bps. The G4 isn't that bad of a gun. If you get it from a paintball store that backs their products and you know how to maintain a gun it's a no brainer to use. I have the G4. Had a small leak from the line but the store fixed it for free and also replaced the fittings just cause he wanted to. The Etek 3 is a better gun than the G5 imo. Jump on that deal. Before you buy any gun you should do your research. I knew that the G4 would leak before I even purchased it. I just liked how the gun felt in my hands. Try going to a paintball store and holding each one and see if they'll let you test shoot them.
#23 TheRealistBaller
TheRealistBaller
    I wear MoonShoes
  • 366 posts
Posted 10 July 2013 - 10:48 PM
Get the rail or eXTcy (however the fuck u spell it) both r good but the rail will have more consistent cronos but the efficientcy is not too good especially if ur gunna get a smaller tank. But then again I don't expect a newer player to need like 8 or 9 pods a game lol
hey i play paintball
#24 TheRealistBaller
TheRealistBaller
    I wear MoonShoes
  • 366 posts
Posted 10 July 2013 - 10:51 PM
Yea, I so had a G4,as long as you keep the bolt lubed with basic baby oil it'll shoot fine. And the etek 3 is good for its price imo, like a lower end ego, and if you get the right ups it basic is an ego...(go ahead and hate me cause I said that all of u lol)
#25 BurningPlaydoh
Posted 11 July 2013 - 12:13 AM
Spool users, please don't use oil on your bolt.  Not baby oil at least...
#26 bigx
bigx
  • 5,116 posts
Posted 11 July 2013 - 09:10 AM
Firstly please post equipment advice threads in the equipment advice section. Secondly look into something like a used ion or extcy both of which are inexpensive solid shooters that leave little to be desired for the price. Never overspend on a first gun. You can get into the hobby rather cheaply if you know where to look and spend smart.
#27 TheDyeingEmpirePlanet
    DP doesn't always leak!
  • 653 posts
Posted 11 July 2013 - 08:43 PM
DP doesn't always leak! They fixed the leaking issue with the g4s
Buy one of these if you want a cheap but nice electro!!!
DP E1!!!
