Guys I need help on a gun! D: I am so stuck
14 replies to this topic
#1 ThePBnewbie
ThePBnewbie
    Homework kills trees!!!
  • 265 posts
Posted 10 July 2013 - 07:18 PM
So on the spyder website you can get the advancer for $99.99 (mrsp $189)
info about the gun: The Advancer™ is the first tournament level .50 Caliber electronic paintball marker from Spyder. Featuring a reduced weight and overall profile, the Advancer™ allows maximum mobility during play. Each Advancer™ comes equipped with the LEAP™ II Circuit Board by Tadao® which delivers silky bolt movement and effortless trigger mechanism. This smaller than traditional .50 Caliber paintball creates a smaller ammunition which means greater accuracy and efficiency, less mess and less impact for the player. With the low recoil of the marker the ball maintains a more accurate flight path capable of placing your shots within a tight grouping. The Advancer™ comes with the patent pending Eko™ Valve System which can get an impressive 3,500 shots with one single 20oz CO2 tank. You can operate the Advancer™ on CO2 or Compressed Air.
+ Air Efficient EKO™ Valve System (Patent Pending)
+ Break Beam Eye (Anti-Chop System)
+ LEAP™ II Circuit Board with Rear Facing Color Access Mode Display (CAMD) Developed by Tadao Technologies with Semi-Auto and the current PSP and Millennium settings
+ Quick Release Bolt
+ 10" Micro Ported Barrel
+ Clamping Collar Feedneck
+ 3-Way Adjustable Magnetic Response "Saber" Trigger
+ Recessed Dual Texture Grip Panels
+ All Aluminum Body Construction
+ High Impact Polymer Trigger Frame
+ Adjustable Fast Charge Low Pressure Inline Regulator
+ Standard Thread Vertical Adapter
+ External Velocity Adjuster
+ Tool Free Striker Plug Design
+ Steel Braided Hose
+ Inline Bottom-line ASA
+ Dual Ball Detents
+ Operates on CO2 or Compressed Air
Included with this marker:
+ 350 Round Gravity Feed Loader
* Battery and charger not included
picture of the Spyder Advancer
_____________________________________________________________________________
Or the Azodin Kaos
FEATURES:
LOW RISE “TWIST LOCK II” FEED NECK
FEATHER STRIKER SYSTEM
TOP COCKING PULL PIN
QUICK RELEASE DELRIN BOLT
12” SINGLE PIECE BARREL
DOUBLE BALL DETENTS
GAS-THRU FOREGRIP
NON-SLIP RUBBER GRIP PANELS
ALUMINUM GRIP FRAME WITH DOVETAIL AND DIRECT SCREW MOUNT
OPERATES ON CO2 OR HPA
#2 Feerless
Feerless
    Got Gogged?
  • 78 posts
Posted 13 July 2013 - 01:46 PM
Normal paintball guns are .68 caliber, I wouldn't recommend the advancer.
FEAR Feerless  :P
#3 NICKMISIU
NICKMISIU
    Smartass of forever
  • 328 posts
Posted 13 July 2013 - 07:15 PM
Dont go for 50 cal guns, not popular or powerful enough. GO for something else like the kaos, or a used enemy or new envy
Doesn't matter what gun you have, how old you are, what paint you shoot, who your up against, how bad of a day you had... All that matters is that your playing paintball now.
#4 III Kezia III
III Kezia III
    Lulzjustbeingacat :D
  • 867 posts
Posted 13 July 2013 - 08:49 PM
never get a .50 cal as your first marker, you wont really have fun with having to go out of your way to acquire things, such as paint ( chances are your local field doesnt carry .50) sanding down the hopper feedneck on the tippmann fasta to .ensure it fits, etc etc
#5 garrenfolts9
garrenfolts9
  • 1 posts
Posted 11 August 2013 - 07:34 PM
If your stuck on spyder get the Fenix 2012. I recently purchased it from my local shop and its a pretty fantastic gun for the price (150$). Its an electronic paintball marker and is tournament ready with psp and mellinium ramping. Dont get me wrong im already looking at higher end guns but with the fenix i cant complain.
The Fenix is the same marker but it shoots .68.
#6 TIGREX ZX
TIGREX ZX
    The Asian guy that picks your rice.
  • 312 posts
Posted 12 August 2013 - 09:12 AM
If you are looking for a entry level marker don't get a Spyder unless your heart desires on it. Try a GoG eNEMy, or an Envy.
Why hello there :)
Livin' that luxe life
#7 Pvlacrosse14
Pvlacrosse14
    Indians Football OG #67
  • 2,398 posts
Posted 12 August 2013 - 03:42 PM
This
My Setup- 2k11 G6R, Virtue Spire 260, Ninja Pro V2 68/45, Empire Events, 2013 NXE Elevation
#8 Duck ON Quack
Duck ON Quack
    Save a rock, Throw a Mini
  • 265 posts
Posted 12 August 2013 - 04:35 PM
Yeah... Just dont get a Spyder. Honestly if you could save up a little bit i would go with an eXTCY or Rail. But thats just me.
there was this one time, when i cared what you thought.
oh... wait. No there wasn't.
#9 Pyeuwnie
Pyeuwnie
  • 145 posts
Posted 13 August 2013 - 12:45 AM
Well beginner markers.. For the price and performance I'd go any with the gog markers like the extcy and some azodins like the blitz instead
#10 Duck ON Quack
Duck ON Quack
  • 265 posts
Posted 13 August 2013 - 01:24 AM
Nah man if you get an Azodin marker you might as well be buying a Spyder. If you get anything below an eXTCY or Rail you are waisting your money, in my opinion...
#11 Pyeuwnie
Pyeuwnie
  • 145 posts
Posted 13 August 2013 - 10:14 AM
Well I guess you're right but don't azodins and spyders have differences? Andi kinda agree about not getting below an extcy cuz you might want something quite better than the rentals they have in fields . since you're buying your own equipment too.
#12 Duck ON Quack
Duck ON Quack
  • 265 posts
Posted 13 August 2013 - 02:16 PM
Azodin's are known as "Spyder Clones". There is a reason for that. Both use the same inneficient, kicky, loud blowback bolt system.
The only difference between the 2 is Azodin markers have better quality aluminum.
My first marker was a Blitz, and i can tell you will enjoy using the extcy much more than any other gun at that price range. I have an Axe and a Victory Ripper, and when i go out the the field for casual or team practice, i use my eXTCY. It is a great shooting, fun marker to play with, and it can do anything a mid-end gun can do. You will be a lot happier if you save up for the eXTCY.
You can always try to find one used for about $170. You just have to look.
#13 TIGREX ZX
TIGREX ZX
  • 312 posts
Posted 13 August 2013 - 02:42 PM
Are you looking to buy brand new or used?
Why hello there :)
#14 BraiNfreeZe
BraiNfreeZe
  • 960 posts
Posted 13 August 2013 - 09:57 PM
This
ThisX2
#15 Brum4500
Brum4500
  • 30 posts
Posted 17 August 2013 - 03:11 PM
If you want a mechanical gun, go with the GOG eNEMey. It has a really amazing trigger! If you want a electric go with the eXTCy.  You won't be disappointed with either one.
