HELP WITH INVERT MINI!
9 replies to this topic
#1 TheSlaughterHawk
TheSlaughterHawk
  • 36 posts
Posted 12 July 2013 - 04:39 PM
Hey guys, I wa at the feild with my invert mini ( all stock ) and I shot about 8 paintballs and the psi inside the gun goes down to zero. In result paintballs just fall out of the barrel. If u hav any questions then just ask AND PLEASE HELP
#2 LUXOR54
LUXOR54
    TechPB's smart ass
  • 4,179 posts
Posted 12 July 2013 - 04:41 PM
do you have air in your tank? is the tank screwed in all the way? after the marker gasses up you should give it an extra half turn in.
#3 The Bacon Man
The Bacon Man
  • 4,201 posts
Posted 12 July 2013 - 08:05 PM
This.  If you don't screw your tank in all the way, it feels like it has a recharge period.  Like you can shoot really slow, but not fast.
#4 Cj R
Cj R
    TechPB's Grazi
  • 695 posts
Posted 12 July 2013 - 09:04 PM
I'm willing to bet it's what's mentioned above, the tank isn't screwed in all the way. Mini's have very snug threading. Put a very small amount of tri-flow lubricant on them and it should help out.
Feedback http://www.techpb.co...howtopic=219021 2/0/0
The best customer service is the one you don't have to call in the first place.
#5 The Bacon Man
The Bacon Man
  • 4,201 posts
Posted 12 July 2013 - 09:09 PM
Yup, Tri Flow or White Lithium Grease.  Don't bother with Dow 33 or oil, it does nothing.
#6 TheSlaughterHawk
TheSlaughterHawk
  • 36 posts
Posted 12 July 2013 - 09:12 PM
It's not the tank I'm possitive about that, if I screwed the tank on any more it would destroy the asa haha but thanks any way
#7 BurningPlaydoh
Posted 12 July 2013 - 10:08 PM
Why...
#8 The Bacon Man
The Bacon Man
  • 4,201 posts
Posted 12 July 2013 - 11:16 PM
Why...
I found it in my garage and put it on my threads, my direct mount screws in like butter.
#9 TheSlaughterHawk
TheSlaughterHawk
  • 36 posts
Posted 12 July 2013 - 11:41 PM
#10 imnothim
imnothim
  • 98 posts
Posted 13 July 2013 - 03:07 PM
This may seem overly simplistic but try a brand new, fresh battery. I have a mini as well and a low battery does weird things (in all markers really) including not advancing the bolt fully resulting in your paintballs going about 10ft.
