GOG extcy problem
gog extcy regulator
1 reply to this topic
#1 mvenes
  • 2 posts
Posted 12 July 2013 - 04:58 PM
Got my new gog extcy yesterday, but now i have a problem. I cant change the velocity on my marker. the allen screw is suppose to be easy to turn, but is now  impossible to srew. if i turn the screw counter-clockwise, then i screw of the hole regulator. Please help my with my problem! Is this something i can fix? or must i return it to gog?
I have attacht a picture of where the velocity allen screw is!
  • 22,435 posts
Posted 12 July 2013 - 05:02 PM
Hold the reg in your hand when you try to adjust the screw. That way you can keep it from unscrewing off the gun. Also, are you sure you haven't just screwed it all the way out already?
Also tagged with one or more of these keywords: gog, extcy, regulator
