Help with dwell settings
dangerous power g4 dp dwell board electonic techt bolt techtbolt boltstick
6 replies to this topic
#1 nate6283
nate6283
  • 9 posts
Posted 22 July 2013 - 11:16 AM
I have a Dangerous Power G4 and I just purchased a Techt L7 Bolt for it. I was wondering if anyone new any good settings for the board to get maximumperformance and efficiency for my gun. Thanks!
#2 LUXOR54
LUXOR54
    TechPB's smart ass
  • 4,141 posts
Posted 22 July 2013 - 11:20 AM
use the settings that techt says to use. they say you can lower the dwell, i'm not sure by how much though.
DLX Luxe, 2k5 ccm'd superstock. up north where we like maple syrup and hockey.
#3 andrewthewookie
    Shaaaaaaaaaaaaaaaaarks :(
  • 21,966 posts
Posted 22 July 2013 - 11:21 AM
Leave it on stock dwell for a day of play, then over a chrono, start decreasing your dwell by one increment while taking about 5 shots each time. Once you get to a dwell setting that is inconsistent or doesn't work, turn the dwell back up to the nearest dwell that shoots consistently.
Hybrid SFT 09 Impulse HB REV-i Macroless Mech Ion
Rotor Grillz PE 70/45 Feedback - 23/0/0
Closer & Angel A1 F/S/T
#4 nate6283
nate6283
  • 9 posts
Posted 24 July 2013 - 08:46 AM
THANKS for help! ill will try your advice. Is there any thing else i should change or is the dwell all?
#5 Pvlacrosse14
Pvlacrosse14
    Indians Football OG #67
  • 2,567 posts
Posted 24 July 2013 - 09:01 AM
I think the lLPR likes to be lowered with the l7 but I may be wrong
#6 andrewthewookie
  • 21,966 posts
Posted 24 July 2013 - 12:38 PM
The G4 has no LPR...
Nate: You don't need to worry about any other settings, just the dwell for now.
Edited by andrewthewookie, 24 July 2013 - 12:38 PM.
#7 nate6283
nate6283
  • 9 posts
Posted 24 July 2013 - 03:17 PM
THANKS!
Also tagged with one or more of these keywords: dangerous power, g4, dp, dwell, board, electonic, techt, bolt, techtbolt, boltstick
