Tippmann A5 Flatline Problem
Tippmann A5 Flatline Problem Cleaning
5 replies to this topic
#1 SHMadPup
SHMadPup
  • 1 posts
Posted 30 July 2013 - 03:43 PM
This past weekend my Tippmann A5 (Older Version) with a Flatline Barrel, and a response trigger kept breaking balls. About every 3-5 shots was a broken ball. I was shooting Marballizer tournament grade paintballs. It shot great the first day, no problems, not one broken ball. The second day I couldn't shoot it without breaking a ball. Two other people from my group were using flatlines on A5's as well, they had no issues. I squeegeed the barrel several times, and ran water through the barrel, went back out, and had the same problem. I put my stock barrel in, and had no problems. Shot just fine, no broken balls. Which leads me to believe it's the flatline. Has the barrel gone bad? Do I have to do something other than squeegee it, cleaning wise?
#2 bassfisher
bassfisher
  • 2,100 posts
Posted 30 July 2013 - 06:41 PM
I would take the barrel off and try to look for visible scratches or grooves. Sounds like there could be a rough spot on the inside that's breaking the paint.
Carolina Riot Scenario Team
#3 Pvlacrosse14
Pvlacrosse14
    Indians Football OG #67
  • 2,637 posts
Posted 30 July 2013 - 06:44 PM
It might just be a factory defect. Definately take the barrel off and look for anything bad
#4 Cookybiscuit
Cookybiscuit
    Schadenfreude Fanatic
  • 15,660 posts
Posted 30 July 2013 - 07:04 PM
If it continues to be a problem email Tippmann and they'll replace it for nothing.
#5 XGC_Cheevo
XGC_Cheevo
    Pod Scalping You
  • 3,026 posts
Posted 30 July 2013 - 09:02 PM
Tournament grade paint in a flatline could also be the issue.  They aren't known for being gentle on anything more brittle than rec paint.  Yes I realize the OP had no issues previously.
#6 Pvlacrosse14
Pvlacrosse14
  • 2,637 posts
Posted 31 July 2013 - 09:11 AM
^but it says that other people on the same day using the same paint and flatlines had no problems
Also tagged with one or more of these keywords: Tippmann, A5, Flatline, Problem, Cleaning
