I need help with an old school autococker i'm about to get and turn into my first pump gun
#1 liamharrington225
liamharrington225
  • 2 posts
Posted 07 August 2013 - 06:09 PM
I am about to get a wgp 2000 autococker. I would like to know if a WGP Autococker Pump Conversion Kit 2K will that fit I'm still new to this whole thing. Any help would be very appreciated.
Here is a link to the pump kithttp://www.paintball...aupucokit1.html
Thank You For Reading
  • 22,431 posts
Posted 07 August 2013 - 06:14 PM
Yes, it should fit just fine.
#3 liamharrington225
liamharrington225
  • 2 posts
Posted 07 August 2013 - 06:16 PM
OK thank you so much
#4 EgoPossum
EgoPossum
    Playin' pump & Hurtin' Feelings
  • 182 posts
Posted 09 November 2013 - 10:55 AM
One of the problems I had with the WGP pump kits is that they are prone to wobbling, twisting and binding (if you are me).  They depend on the barrel to keep the pump handle centered and if you use something like a deadlywinds barrel (small OD) there is alot more play in the pump stroke.
I had a 2k2 STO with that exact pump kit.  I got one of the Gat Factory Universal Pump Arm Guides at the OSC in St Louis a few years back and it eliminated all the unwanted play in the pump stroke
http://www.autococke...bilizer-11.html
One of my snipers has this exact pump kit on it.  It is $20 more then the basic WGP pump kit but has very little play because of the built-in pump arm guide.
http://www.ebay.com/...=item2331b74157
"I shoot pump because it hurts more feelings." -- ryantuomi (heard at Living Legends 2)
"Pumping is about as much a disadvantage for me as shifting is for a Nascar driver" - good buddy of mine said this when we were talking about going against the local tourney team
Thunder Bay Pump Club
Dementia Paintball
#5 Darrow
Darrow
    SC4LYFE
  • 238 posts
Posted 10 November 2013 - 12:43 AM
^^What he said.
If you choose to make the investment, you will be hooked on the ccm kits.  They are extremely well made.
You missed me at a rate of 22 balls per second and you're going to try and tell me your gun has eyes??
