Magna Drive problems...
#1 116clique
116clique
  • 45 posts
Posted 16 October 2013 - 11:21 PM
Sooo.... I picked up two magnas for pretty cheap to have for people who come play paintball and borrow my gear. After taking one apart, the wires on the motor came off. No biggie, right? So I had them re-soldered in the same order back to the contacts of what I believe to be a capacitor. The motor still would not turn. I disassembled the motor and found a small copper piece out of place. After surgery-like procedures because they were SOO SMALL, I reassembled the motor and hopper only to find that the drive wheel spins clockwise instead of counterclockwise... Effectively doing (as Chris Farley would say) JACK SQUAT. Therefore, any help would be appreciated.
  • 22,435 posts
Posted 16 October 2013 - 11:30 PM
If it spins backwards, just swap the wires on the motor.
#3 116clique
116clique
  • 45 posts
Posted 17 October 2013 - 12:07 PM
So cut and re-solder them again? I have two motors, and I soldered the wires on the broken one like I found them on the one that works. White on the left, grey on the right..
#4 andrewthewookie
  • 22,435 posts
Posted 17 October 2013 - 12:09 PM
If it's spinning the wrong way, then re-soldering the wires on the opposite contacts of the motor is the only solution.
Edited by andrewthewookie, 17 October 2013 - 12:09 PM.
#5 116clique
116clique
  • 45 posts
Posted 17 October 2013 - 12:37 PM
Ok.. will do! Thanks wookie!
