Azodin Blitz reg problems need advice!
#1 AzodinBlitzPrblmz
AzodinBlitzPrblmz
  • 2 posts
Posted 26 October 2013 - 03:49 PM
Ok so I just bought my first electronic gun which is the Azodin Blitz. I have used it around 4 times. Last night with some friends I was shooting it in my backyard and all of the sudden air started leaking everywhere. Upon investigation, my R033 Inner Regulator oring has broken. The only problem is that I have no idea on how to fix it. All the youtube videos I have watched haven't helped because you cant take that part of the regulator apart. At this point I want to get a new regulator instead of easily replacing the orings because in all the oring rebuild kits for the blitz they dont come with the R033 ring. So what you reg can I get that will work on the blitz? Or what can I do to replace the oring? THANKS in advance!
#2 tallsmallboy44
Posted 26 October 2013 - 05:07 PM
Call Azodin. They should be able to either send you the parts, walk you through how to fix it, or give you instructions on how to send it in so they can fix it. If you know the exact size of the oring all you have to do is put a new one on.
#3 smurfinator22
smurfinator22
  • 710 posts
Posted 26 October 2013 - 05:42 PM
you wont be able to replace that oring unless you have an oring pick
my suggestion would be to take the reg into a proshop to get it fixed
they will have all of the parts and tools to fix it
#4 AzodinBlitzPrblmz
AzodinBlitzPrblmz
  • 2 posts
Posted 27 October 2013 - 10:47 AM
Thanks you two. Im going to my local hardware store to see if they have the right size and type of oring. Fingers crossed!
#5 tallsmallboy44
Posted 27 October 2013 - 04:10 PM
Your hardware store may not have what you need.
Here's a TechPB thread that might help http://www.techpb.co...howtopic=129520
