Battery storage?
6 replies to this topic
#1 PB4fuun
PB4fuun
  • 144 posts
Posted 27 October 2013 - 11:23 AM
Was just wondering if it would be a good idea to leave my battery in my gun after playing. Like will it use up the batteries juice when it's just sitting there in storage with the gun off? I use a 2011 proto rail if it would make a difference any help would be nice.:)
#2 C.Klapper
C.Klapper
  • 25 posts
Posted 27 October 2013 - 11:32 AM
It says in the owners manual that if you don't plan on using your gun for a month or longer then you should take out the battery. Don't really know if that helps you or not, good luck
#3 PB4fuun
PB4fuun
  • 144 posts
Posted 27 October 2013 - 11:40 AM
Ok, I lost the manual so thanks.
#4 Sydarm
Sydarm
    XTC + Ninja + Pinokio
  • 1,977 posts
Posted 27 October 2013 - 02:00 PM
Some guns eat batteries worse than others if you leave them in. I haven't ever had a problem with my Proto eating batteries. I leave the 9v in it.
If you ever have a gun with a blackheart board, then you can never leave a 9v in it.
Edited by Sydarm, 27 October 2013 - 02:02 PM.
#5 tallsmallboy44
Posted 27 October 2013 - 04:07 PM
I'd take the battery out just to be safe
#6 dustyshouri
dustyshouri
  • 160 posts
Posted 27 October 2013 - 04:51 PM
Taking them out will save your battery. My brother-in-law and I both got a G-1 and he left his battery in and I took mine out, we didn't end up playing for half a year or so. When we did play, his battery was dead, and my own battery which was set aside lasted the entire day(and probably still has a decent charge).
Not to mention it's just good practice. Eventually you'll come to a point where you stop using the gun(maybe get a new gun or something) and just set it aside, you don't want the battery to eventually leak inside the gun and ruin the components.
#7 PB4fuun
PB4fuun
  • 144 posts
Posted 27 October 2013 - 05:44 PM
Ok thanks for the help everyone!
