G6R Efficiency problems
6 replies to this topic
#1 SplatSplatOrange
SplatSplatOrange
  • 507 posts
Posted 30 October 2013 - 06:45 PM
So i aired up my G6R for the first time today with a ninja slp 45/45 and i shot fine no leaks but i was getting horrible efficiency. i got 3 pods in 3k. my lpr is set at ~60 and the hpr is at set at 160.The gauge on the tank is somewhat cracked could that be the problem? It also has a lp poppit and a pillow bolt
Edited by SplatSplatOrange, 30 October 2013 - 06:46 PM.
<p>G6R Red/black Ninja slp 45/45 Grillz Spire
Member of Chi-Town-Rampage
  • 22,434 posts
Posted 30 October 2013 - 06:49 PM
Do you know if you were underboring or overboring? The LP poppet will decrease efficiency over the standard poppet. Also, IIRC the LPR is factory set between 65-75 psi, so you're running a bit low of that. The low LPR combined with the LP poppet could be part of the issue.
Edited by andrewthewookie, 30 October 2013 - 06:49 PM.
#3 SplatSplatOrange
SplatSplatOrange
  • 507 posts
Posted 30 October 2013 - 06:52 PM
ok, its a 691  barrel which is a pretty big overbore, i was shooting crappy paint also
#4 Sydarm
Sydarm
    XTC + Ninja + Pinokio
  • 1,977 posts
While a more empty tank would invalidate your test, 2 of my ninja tanks have the exterior plastic face of the gauge cracked. They work fine.
#5 SplatSplatOrange
SplatSplatOrange
  • 507 posts
Posted 30 October 2013 - 07:00 PM
so i raised my lpr to ~70 will that help or should i shoot for the middle
Edited by SplatSplatOrange, 30 October 2013 - 07:03 PM.
#6 SplatSplatOrange
SplatSplatOrange
  • 507 posts
Posted 30 October 2013 - 07:26 PM
my dwell was alos a little high ~8-9 could that contribute?
#7 Beau A
Beau A
  • 1,035 posts
Posted 05 November 2013 - 06:04 AM
Running a higher dewll and using a LP poppet will both cause efficiency loss. My suggestion would be to clean your regs first, second set your dwell to 6 which is stock and sweet spot your regs at that.
