Etek psp problem
#1 JG3baller
JG3baller
  • 42 posts
Posted 30 October 2013 - 11:34 PM
I wouldn't really say this is a problem but regulation PSP requires 3 shots before the gun goes into ramping but on the etek you have to shoot 5bps in order for it to start ramping. Does anyone know if i can make this gun shoot regulation psp? i'm pretty sure i've seen it on youtube but the manual does not explain it.
#2 BurningPlaydoh
Posted 30 October 2013 - 11:52 PM
That is regulation PSP...
#3 JG3baller
JG3baller
  • 42 posts
Posted 31 October 2013 - 12:09 AM
no  its not. Its not even 3 shot its just ramping..
#4 smurfinator22
smurfinator22
  • 710 posts
Posted 31 October 2013 - 01:05 AM
the three shots you are referring to are called safety shots
this means you have to pull the trigger 3 times before you can initiate ramping
the 5bps on the other hand means that you need to maintain 5 trigger pulls per second in order to keep your stream of paint going
so the mode is regulation, you just need to pull the trigger 3 times at 5bps to go into ramping and keep pulling at 5bps to maintain ramping
i think you're mixed up between psp 3 shot and psp ramping
they are two different modes
both require the three safety shots but the difference between the two is each trigger pull on three shot will give you three shots, whereas with ramping you will get X amount of shots depending on how long you pull the trigger, and if you maintain 5 pulls per second.
hopefully that cleared some things up
Edited by smurfinator22, 31 October 2013 - 01:06 AM.
#5 BurningPlaydoh
Posted 31 October 2013 - 01:23 AM
Then maybe you should have said PSP Burst/3 shot in the OP.
Also the way you worded it made it sound you though needing 4bps to get into ramp was incorrect.
