Empire Mini Bolt Problem..
7 replies to this topic
#1 Lebby
Lebby
  • 42 posts
Posted 02 November 2013 - 09:58 AM
So I went to shoot my mini today but it was only firing like every other or every 3rd shot but the air was still going just no ball was going... so i took off the hopper and looked at the bolt problem is when i shoot it it doesn't return all the way in so it's in the breach therefor no balls can get into place... I tried lubing it didn't help and Idk what to do..
#2 kingJurzy
Posted 02 November 2013 - 10:26 AM
is the spring in there and if so is it in correctly?
#3 Toxin PB
Toxin PB
    California Baller
  • 567 posts
Posted 02 November 2013 - 10:39 AM
Check all bolt o rings and replace if they are worn
#4 Lebby
Lebby
  • 42 posts
Posted 02 November 2013 - 11:09 AM
Yeah I checked the spring and how exactly do I tell if the O-Rings are worn (I doubt they are only shot like 10 cases or so out of it though)
#5 imnothim
imnothim
  • 98 posts
Posted 02 November 2013 - 11:38 AM
Might seem simple but try a new battery. Not one you find in a drawer lol.
Is air leaking from anywhere at any point during the firing cycle?
#6 kingJurzy
Posted 02 November 2013 - 11:40 AM
Another thing I can think of is resetting the board. What does the pressure read on the gauge?
#7 andrewthewookie
  • 22,431 posts
Posted 02 November 2013 - 06:49 PM
The bolt returning fully isn't really an issue with a battery or board, it's completely up to the bolt spring to do that.
Do you have the stock bolt? When you move the bolt back and forth on the bolt guide by hand, does it feel hard to move, or does it slide smoothly? Also, does the bolt spring look bent at all?
#8 Lebby
Lebby
  • 42 posts
Posted 03 November 2013 - 11:07 AM
Oh guys I fixed it just needed to be completely cleaned before re-lubed lmao-_- but thanks for the help :P
