Proto Rail barrel problems
proto rail barrel problems
9 replies to this topic
#1 ASIAN invASIANx
ASIAN invASIANx
  • 25 posts
Posted 03 November 2013 - 11:51 PM
Today, I was at my local field playing recball. Right before we went out to the actual field, i went to go chrono. But as I was pulling the trigger, only air was coming out, no balls. My gun was on, my rotor was on, the balls were even shooting past the detents. But for some reason, the balls kept getting stuck in the barrel; some got stuck near the front, others near the back, some didn't get stuck at all. When i looked through the barrel (not attached to the gun of course) i noticed that the balls were only stuck at two places opposite sides from each other (like the north and south poles). Why did this happen so suddenly, even though I'm using the same paint as I did when I last played? Is it a problem with the barrel or the paint?
#2 SplatSplatOrange
SplatSplatOrange
  • 507 posts
Posted 03 November 2013 - 11:58 PM
Problem with gun or tank not barrel
Edited by SplatSplatOrange, 03 November 2013 - 11:58 PM.
<p>G6R Red/black Ninja slp 45/45 Grillz Spire
Member of Chi-Town-Rampage
#3 andrewthewookie
  • 22,432 posts
Posted 04 November 2013 - 12:01 AM
Yeah, it sounds like your gun wasn't shooting fully.
#4 ASIAN invASIANx
ASIAN invASIANx
  • 25 posts
Posted 04 November 2013 - 12:06 AM
My tank was recently filled and after i noticed this happening, I took out the bolt and cleaned/lubed it
#5 andrewthewookie
  • 22,432 posts
Posted 04 November 2013 - 12:08 AM
For paintballs to get stuck in the barrel, your gun wasn't shooting at normal velocity. Either you turned the pressure down on your reg, the dwell was way down, or you need a new battery. If the gun had normal pressure coming out of the bolt, then it would be pretty much impossible for the paintballs to get stuck.
Edited by andrewthewookie, 04 November 2013 - 12:09 AM.
#6 ASIAN invASIANx
ASIAN invASIANx
  • 25 posts
Posted 04 November 2013 - 12:20 AM
I think it was the dwell, I remember messing with that before I played today. Thanks for the help!
#7 III Kezia III
III Kezia III
    Lulzjustbeingacat :D
  • 878 posts
Posted 04 November 2013 - 12:28 AM
never play around with dwell unless it is essential
#8 Sydarm
Sydarm
    XTC + Ninja + Pinokio
  • 1,977 posts
Posted 04 November 2013 - 01:09 AM
Well, at least finish tuning before trying to play if you screwed with it. The symptom you are having is very indicative of low dwell.
#9 ASIAN invASIANx
ASIAN invASIANx
  • 25 posts
Posted 04 November 2013 - 11:39 PM
Yea, i lowered it down, but i have since raised it back to the factory default
#10 michael_mnm
michael_mnm
  • 143 posts
Posted 05 November 2013 - 10:12 PM
I think the lowest dwell you can go on a rail is like 30 milliseconds
PLAYING CFPS!!!!!!!!!
Also tagged with one or more of these keywords: proto, rail, barrel, problems
