Gopro Tripod Mount Stops Shaking?
gopro mount tripod
#1 yurij13
  • 7 posts
Posted 09 November 2013 - 12:44 AM
alright so im wondering since i have a hero 3 go pro, and if you hold it in your hand its to small and it will probably shake if you move around. i just want to take recording shots of everything while like walking around.
in this video
how do they make the camera so still and smooth?
do they use a hand held tripod mount or one they put on the ground?
and what do you reccomend me doing?
#2 The Recballer
The Recballer
    Liberty University
  • 1,249 posts
Posted 09 November 2013 - 02:52 PM
They likely use a glidecam.
Chelsea Football Club - St.Louis Rams - Tampa Bay Rays - Florida Panthers - Miami Heat
Tampa Bay Damage - San Diego Dynasty
Liberty University Paintball
#3 smurfinator22
  • 710 posts
Posted 09 November 2013 - 07:45 PM
ive seen cassidy use a tripod that he braces against his body when hes filming and moving at the same time
shoulder stabilization equipment works well if you're filming with a DSLR or video camera but seems a little much for a gopro
fluid head tripods are the best for smooth video if you're stationary and most videographers use those
for your gopro and the type of filming you do i suggest looking at something like this http://www.amazon.co...84044250&sr=1-8
