Buying surplus parts for a used gun
Orings Lube
13 replies to this topic
#1 TeAreOhWhy
TeAreOhWhy
  • 120 posts
Posted 12 November 2013 - 10:00 PM
I'm ordering my droid tomorrow and it's used but really only comes with the marker and barrel. My last used marker came with everything but lube and allen keys. Should I pick up some o-rings from o-ring monkey when I get it? And I have Hater Marm but I heard it's better for asa and reg lubing, what should I use to lube the bolt/breech with? Or will Marm suffice?
#2 kingJurzy
Posted 12 November 2013 - 10:08 PM
it should be ok but I would pick up an oring kit that is universal and DOW 33
#3 slinkyaroo
slinkyaroo
  • Root Admin
  • 4,900 posts
Posted 13 November 2013 - 03:23 AM
Extra orings, lube and Allen keys are a must.
#4 Wolfe
Wolfe
  • 813 posts
Posted 13 November 2013 - 09:35 AM
If you're going to service your own markers, no matter which one it is. You want the allen keys, o-rings and lube. Without a doubt.
#5 TeAreOhWhy
TeAreOhWhy
  • 120 posts
Posted 13 November 2013 - 11:10 AM
I have hater marmalade but should I get a different thinner lube? or will marmalade work for all purposes?
#6 BurningPlaydoh
Posted 13 November 2013 - 11:28 AM
I can pretty much guarantee that'll be too thick. The new Macdev Militia lube is your best bet. Make sure you get the tube and not the jar to make sure its the new formula.
#7 TeAreOhWhy
TeAreOhWhy
  • 120 posts
Oops didn't see your reply before I posted that last post, are you referring to the TechPB o-ring kit? Thats the only one I see
#8 TeAreOhWhy
TeAreOhWhy
  • 120 posts
Posted 13 November 2013 - 11:31 AM
Can I use marmalade for reg/asa servicing? Or should I get Militia lube and just use that throughout the entire marker?
#9 tallsmallboy44
Posted 13 November 2013 - 03:25 PM
Just use Marmalade for now. If it doesn't work out, I'd suggest Lurker Lube.
#10 TeAreOhWhy
TeAreOhWhy
  • 120 posts
Posted 18 November 2013 - 06:59 PM
The droid I purchased comes with a tub. Is there something wrong with the old formula?
#11 TheGuy
TheGuy
    I like lamp
  • 13,799 posts
Posted 18 November 2013 - 08:10 PM
It should work fine. Try it out to see. Worst case scenario is you have some bolt stick.
#12 TeAreOhWhy
TeAreOhWhy
  • 120 posts
Posted 18 November 2013 - 08:32 PM
Haha isn't the whole point of lube to prevent bolt stick? I'll try it out as soon as it comes
#13 TheGuy
TheGuy
    I like lamp
  • 13,799 posts
Posted 18 November 2013 - 08:47 PM
The purpose of lubricant is to reduce friction, and with orings, help seal air. Some lubes have a higher viscosity which leads to bolt stick.
#14 BurningPlaydoh
Posted 18 November 2013 - 09:14 PM
Lurker Lube is too thick for a Droid/Clone IMO. What is wrong with using the manufacturer developed and recommend lube?
Also tagged with one or more of these keywords: Orings, Lube
