Help me fix my friends ego 7
8 replies to this topic
#1 The Recballer
The Recballer
    Liberty University
  • 1,249 posts
Posted 28 December 2013 - 04:44 PM
Here is the video:
Shortly after this was filmed my mom said she heard a pop noise come from my room. I ran in and checked his gun. Turns out the ASA assembly shot out the back of the gun.
What do?
Edited by The Recballer, 28 December 2013 - 04:47 PM.
Chelsea Football Club - St.Louis Rams - Tampa Bay Rays - Florida Panthers - Miami Heat
Tampa Bay Damage - San Diego Dynasty
Liberty University Paintball
#2 The Recballer
The Recballer
    Liberty University
  • 1,249 posts
Posted 28 December 2013 - 04:48 PM
Just realized I never tried a new battery.
#3 bigx
bigx
  • 5,116 posts
Posted 28 December 2013 - 04:50 PM
Check the ASA Plunger Orings that might have to do with the gush of air.
The noid still cycles so thats a good sign.
Older Egos also have QEVs be sure to check not only all the hoses but the diaphragms as well.
Go into the gun clean absoloutely everything and re lube all the orings.
If you are confident service the noid as well.
Throw in a new battery and a fresh clean lube job and you should be ok.
Edited by bigx, 28 December 2013 - 04:51 PM.
#4 The Recballer
The Recballer
    Liberty University
  • 1,249 posts
Posted 28 December 2013 - 04:57 PM
Tech pb, your website is broken, I can't reply to anyone.
Anyway, plunger oring is good. I'll try a new battery, but other than that, I think I'm going to let him take it to a tech.
#5 BiggieCheez
BiggieCheez
    TechPB's Cheeziest player of 2014
  • 190 posts
Posted 28 December 2013 - 05:11 PM
is it in training mode? sounds stupid but it has happened to me mid game.
Ebay feedback  http://www.ebay.com/usr/biggiecheez
BST Feedback 3/0/0
#6 The Recballer
The Recballer
    Liberty University
  • 1,249 posts
Posted 28 December 2013 - 05:18 PM
Nope
#7 BurningPlaydoh
Posted 28 December 2013 - 06:07 PM
Is that the stock bolt? If so its not inserted correctly. The contours on the back of the bolt must line up with the milling on the back of the top tube of the gun whe. the bolt is in the rearward postion. Right now the bolt pin is preventing the ram from reaching and striking the valve. All its doing is moving the ram and bolt back and forth enough to push a few balls down the barrel.
Edited by BurningPlaydoh, 28 December 2013 - 06:15 PM.
#8 bigx
bigx
  • 5,116 posts
Posted 29 December 2013 - 07:35 PM
Check the QEVs
#9 bassfisher
bassfisher
  • 2,100 posts
Posted 17 January 2014 - 12:30 AM
take the hopper off and pull the bolt out, if you here a leak with the bolt out check the ram o-rings.
EDIT: derp. accidental almost necro post.
Edited by bassfisher, 17 January 2014 - 12:31 AM.
Carolina Riot Scenario Team
