Solenoid Leak Smart parts SP1
solenoid leak smart parts board
1 reply to this topic
#1 Omarfernando
  • 12 posts
Posted 21 January 2014 - 09:59 PM
I have a smart parts sp1 with a leaking solenoid, Is it worth fixing or should I look into a new solenoid and if so where can I buy the solenoid without the board as the board is still good. Thanks
#2 Punisher068
  • 216 posts
Posted 22 January 2014 - 02:28 PM
Try adjusting your reg lower 1st,the noid is ment to vent pressure to prevent it from ruining the noid.
If it stops leaking and will cycle it's probably still good.
If you can get it to stop leaking and it will fire but not crono to field speed adjust your board dwell setting upwards
Also tagged with one or more of these keywords: solenoid, leak, smart parts, board
