Best Speed Feed for a Dye Rotor
8 replies to this topic
#1 Nate1340
Nate1340
  • 19 posts
Posted 04 February 2014 - 08:46 AM
I was looking into getting a speed feed for my Rotor and was wondering which one people liked the best and why.
#2 pber709
pber709
  • 206 posts
Posted 04 February 2014 - 01:12 PM
i personally like the dye made speed feed. Imo its the best one
If you want to be on a team and are in the Chicagoland area pm me.
Save a rock, throw an Ion!
#3 PREDATOR 47
PREDATOR 47
  • 2,420 posts
Posted 04 February 2014 - 01:15 PM
The Exalt speed feeds are really nice, and I think the older design is about 15 bucks. Still works great, and doesn't cost that much. If you wanted to shell out more money, you should get the Crown SF. Although it's almost 50 dollars, it is by far the best speedfeed you can buy, and I feel like it will outlast all the rubber ones.
#4 BurningPlaydoh
Posted 04 February 2014 - 02:02 PM
Crown SF, HK Army or Exalt (either Exalt one) depending on how much you want to spend.
#5 Talucci
Talucci
    Canadian Baller
  • 1,533 posts
Posted 04 February 2014 - 03:08 PM
Crown SF works amazing for me, exalts are great too
#6 Lotus
Lotus
    Tech Guy
  • 4,930 posts
Posted 04 February 2014 - 03:43 PM
Just a word of caution, the original Dye Speedfeeds work great for a little while, and then start to break. The rubber starts bending in and warping. After some use, they just fall apart. I'd avoid them.
Exalt or the KM speed feed (the HK Army one) work the best in my experience.
Edited by Lotus, 04 February 2014 - 03:43 PM.
#7 SPARTAN1147789
SPARTAN1147789
    SPARTAN
  • 785 posts
Posted 04 February 2014 - 03:58 PM
The virtue Crown SF is the best (due to spring fingers instead of rubber fingers), though if you're on a budget I would say to go with an Exalt Feedgate.
#8 Lt. Blood
Lt. Blood
    Professional
  • 428 posts
Posted 04 February 2014 - 04:50 PM
hk army; by far the best speed feed I've ever used. Around 1 year of use on mine and I'd say about 10 balls have fallen out of the crown even while refilling air and holding the marker upside down while the hopper is loaded. Only issue I'd say is the 5 ball capacity lower you get for the speedfeed but it should be of no issue.
80% of teens listen to Hip-Hop, if you're part of the 20% that hates that shit , put this in your sig!Go ahead and throw your ions. I'll just catch them and throw em' back, except harder You may live in a 500,000 dollar house but i live in a 2 dollar box under a 6,000,000 dollar bridgeSave a rock,throw a tippmann its ok you won't be able to hurt it.put this on ur sig if u feel a need to call paintcheck........even if all you can see is orange! If you live in Panama, hit me up.
#9 PatsPotatoVan
PatsPotatoVan
  • 140 posts
Posted 04 February 2014 - 08:05 PM
I have both the Exalt and the Exalt Fast Feed speed feeds and I love them. The main difference I've found between them is that the regular Exalt takes time to get broken in while the Fast Feed doesn't. It's very rare for paint to fall out of either.
Player
Photographer
Referee
